Question about GE WBSE2090A Top Load Washer
After a wash cycle, there are brown flakes around the tub
These brown flakes are in the clothes and in the tub. I cleaned the "rim" at the top using a mirror. But it looked more like lint with a brownish look. I am running a cycle, agatate then to spin to see if it happens without any clothes.
What else could cause this? The washer is a top load about 7 years old
Dave
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 8 Answers
SOURCE: BROWN GREASY RESIDUE LEFT IN BOTTOM AND TOP OF TUB
could be the transmission shaft rubber seal...need to call service tech for more help thee.
Posted on Apr 07, 2009
SOURCE: machine browning clothes
I have the same prblem
Posted on Oct 13, 2009
  • 10 Answers
SOURCE: will agatate only will not empty the tub
Check to see if there is anything plugging the drain or if there is a kink in the drain hose.
Posted on Apr 22, 2010
Brown dirt spots on some clothes after washing. similar to the wholes in the washer
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
May 06, 2011 | Washing Machines
White residue on dark clothes
Apr 13, 2011 | GE Profile WPRE6100G Top Load Washer
Fine grey powder collected in rim of washer and all over clothes
Mar 28, 2011 | Washing Machines
Hi. I have a Kenmore Elite top-loading washer and in every wash load there are flakes of brown stuff, not rust but more like leaves. There does not seem to be anything wrong with the outflow. Thanks!
Run a few washes of rags or towels with plenty of BLEACH & VINEGAR (two quarts of white) a couple of times to remove most bacterial debris from your machine. There is no part of the machine that "creates" brown flakes, so it is either in the water inflow (check the water) and the way to see what is coming into the machine is to do a "load" without any clothes! Just have the tub fill and look at what fills.....Sounds like something under the tubs upper lip that's coming-off and into your tub during the wash and agitation cycles.
Oct 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
What are the black flakes and how to we eliminate
Did you buy the machine used? It sounds like mildew rinsing off of the outer tub. Try running a load of judt hot water with bleach to clean it out
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washing machine
It sounds like the porcelein on the inner or outer tub is damaged allowing rust to form.
Another possibility is that there are iron deposits in the internal hoses that are loosening.
I would (assuming you can afford the water wastage) run the machine on 'full load' and 'hot' several times with no clothes in it to see if it will flush out.
Jul 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBSE2090A Top Load Washer Logo
156 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
