Question about '98 1998 Ford Windstar Van Key Entry Remote
Vibrates when driving sloworfast not tires - '98 1998 Ford Windstar Van Key Entry Remote
I'm not specifically sure if youv'e had your tire balance checked;but if so,you may have an alignment problem,possibly some axle bearing issues.you need to check all alignment component's and even your engine mounts.
Posted on May 26, 2010
Vibration when diving
Your vibration can be from several different things:
Brake rotors warped, Tire out of balance, lugnuts loose, etc.
The most common reason would be a tire has thrown a weight creating the shimmy. Go to your local tire dealer (i would suggest Les Schwab) they can check it out for free, and usually balance for free too.....
Mar 07, 2016 | 2007 GMC Yukon XL
Some time ago I got new tires put on my 2010 dodge ram 1500 and after that the truck kind of vibrated I figured just the tread off the tire so I ignored the vibrating. Now I currently have abs. Esp....
If it wasn't vibrating before the new tires and was fine then it has to be the tires maybe just one, or sounds like they didn't torque the lug nuts to the right specs, putting the rim out of alignment, but if they took the wheels off to rebalance then that rules that out. I would go to a different tire shop and have them check it out....Also on a long shot they bent something in the suspension when changing the tires, possible fell off the jack or something similar. Good luck
Feb 19, 2015 | Dodge Cars & Trucks
What could be the problem, when i drive my man26.480 truck over 60km/h the truck shakes and vibrates
When you drive the truck at lower speeds, the weight of the truck neutralizes the vibrations. As you speed above 60km /hour, the tires start to vibrate, the circular motion of the tires create a force away from the center of tires, imagine a roulette, that like dice wants to stay away from the center, until the wheel slows down.To compensate for this force, tires are checked for balance. So balancing your tires, hopefully wlil solve your issue.
May 18, 2014 | Bruder MAN TGA Container Service Truck
Vibrations at high speeds
Does it change at all if the tires were rotated?
Apr 19, 2017 | 2007 Ford Expedition EL XLT
Why does my bmw 750i vibrates at 80kms. the tires have been balance
could be a couple things if all wheel drive it could be a drive shaft but just cuz the tires have been balanced desent mean there good u need to look at the tire while spinning on the balancer if it hopes up and down that could be ur side to side is usually a problem it could still be a bent rim aswell usually vibrations at that speed means tires but a shaft is still a possibility
Oct 26, 2012 | 2007 BMW 750i Sedan
Strong front end vibration at speeds over 60 mph. Shocks, ball joints have been replaced and wheels aligned and balanced. Took it to a tire repair shop and they couldn't find problem. Any ideas on...
You need to have someone look at it that is experienced in NVH (Noise, Vibration and Harshness). Front end vibrations can be caused by many things. Each possibility needs to be systematically eliminated to find the cause. Someone who is experienced in this can eliminate several possibilities by simply driving the vehicle...Did the tire shop even bother to road test it? I'll bet not!
Sometimes INTERNAL tire problems can cause a vibration that cannot be found (or eliminated as a possibility) by putting the tires on a balance machine. To eliminate this as a possibility, rotate the tires front-to-rear one side at a time then drive the vehicle to see if the vibration changes or "moves". If it does, then the tire that just got rotated to the rear is the problem.
Also, the vehicle can be run on a lift to see if the vibration can be duplicated in the shop. Many times, if the vibration is being caused by a drive axle or CV joint, it can be located by running the vehicle on a lift this way. In the case of 4-wheel drive vehicles, it will be necessary to engage the front axles to get them spinning on the lift.
The entire steering and suspension system should be checked for looseness in the tie rods, stabilizer links and frame bushings, control arm bushings, etc. Any looseness in any of these parts can cause vibrations at certain speeds.
I have also seen vibrations that act similar to a tire being out of balance that occurs when the brake rotors loose a balancing weight on some vehicles. This may or may not apply to your vehicle, (yours may not have balance weights in the rotors) but this type of vibration can usually also be verified by running the vehicle on a lift.
Jun 12, 2011 | 2002 Hyundai Santa Fe
Vibrating on the passenger side at low speed fory honda 2003 crv
the most common reason for a vibration is most of the time due to a bad tire. check the tire and look for a bubble or what we call a hop in the tire, this is on the tread of the tire not the sidewall. a good way to do this would be on a lift, this will be hard for you unless you spot the bad tire otherwise the crv will need to be put on a lift and ran in drive as you watch the tires spin and look for a hop in the tire, your crv is 4wheel drive which means all wheeels spin so all tire must be off the ground when checking them. if the vibration is at low speed then the bad tire should be easy to find, this is where i would start first, with tire checking, alsomake sure tire pressure are correct, at around 32psi. good day.
Apr 10, 2011 | Honda CR-V Cars & Trucks
2002 Caddy DeVille - slight vibration 60 to 75 mph
I would guess incorrectly tightened or installed wheel bearing. Or it might just need to get greaced.
May 15, 2009 | 1983 Cadillac DeVille
When we drive at 50 miles on the hight way i feel a vibration coming from the underside of the vehicle i don't know if the vibration is coming from the transmission of the engine. But if' not the tires.
Here's the order to check.
The vibration can be caused by;
) Tires needing be balanced
) Tires not inflated properly, or worn with gaps.
) Wheels need to be aligned.
) Steel belts in tires may have slipped.
) Shock/structs worned
May 04, 2009 | Oldsmobile Alero Cars & Trucks
Steering Vibration 2005 Colorlla
your car needs to be aligned and balanced...
Jul 15, 2008 | 2005 Toyota Corolla
'98 1998 Ford Windstar Van Key Entry Remote Logo
67 people viewed this question
Top CAR Plus Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CAR Plus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
