Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher runs, but no water after first cycle or two
The dishwasher runs through the first cycle or two, but then it's stops pumping water. You can here the pump (or motor) making noise, but no water comes out -- This ends up leaving a residue on the dishes. If I stop the dishwasher and then move it to the rinse cycle or restart the cycle it will spray water again.
  • Frigidaire Master
  • 12,061 Answers
Http://frigidaireservicetips.com/pdfs/486_5.pdf
Above is your service manual, below is a DIY self help dishwasher repair site.
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
Please just follow the troubleshooting procedures, and you will soon track down, and remedy your issue. It is possible your pump is blocked or something like that.
Posted on May 27, 2010
Cycle Runs Funny
Hi Bill, this is AP
Based on the symptoms you are describing on how your Frigidaire dishwasher, model PLD2850, is performing I would think that your dishwashers control board could be causing this to happen. Your dishwasher should wash without stopping for longer periods of time. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
If needed you may use the link below to locate a local authorized technician.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Thanks,
Mar 19, 2014 | Frigidaire 24 in. PLD2850 Built-in...
My dishwasher will not drain
could be a blocked drain or faulty drain pump or faulty controller.
Do you have a model no.
Also confirm if the wash cycle did start correctly and it ran through it according to the time. Does the dishwasher stop in the middle of the cycle or it completes the cycle with lights turning off but water still inside.
Did the drain pump actually run?
Sep 06, 2010 | Frigidaire Dishwashers
Dishwasher will not advance through cycles - Frigidaire GLD2250RD
Thanks for writing to Fixya.com.
Is your drain hose stopped up with debris - have a double sink next to the dishwasher. You can plug both drains, one at a time with the water running in the sink while holding the other drain closed. Try it first and if it works, its free, otherwise you may find it's another issue like maybe a bad pump motor on the dishwasher.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 27, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
Dishwasher motor sounds like its struggeling to run. oR LIKE it's bogging down during washing cycles any and all cycles. there is water going into the washer but when washing it sounds like there is no...
Try pouring water from the front. The pump has got air traps inside. This will ease your problem.
Also check whether the spray arm turns freely without any obstacles.
Mar 30, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Hello, I have a Frigidaire Dishwasher, model FDB750RCC1. It will not fully drain. There is water in the bottom of the unit after the cycle is complete. As it is not full of water or leaking out of the...
On the drain hose at the connection to the dishwasher there is a one way check valve. If debris has gotten trapped water will drain back into the dishwasher at the end of cycle
Hope this helps.
Remove the connection and clear.
Jul 01, 2017 | Frigidaire 24 in. FDB750RCC Stainless...
High pitch sound in certain cycles when our frigidaire dishwasher is running
possibly a motor isssue or the pump continuing to run after pumping all the water out...still washing well?
Nov 12, 2009 | Frigidaire FDB1050REM Dishwasher
Fdb4315lfc2 dishwasher keeps filling up
relay switch is sticking in the open position... the float mechanism tells the unit when to stop pumping water out...
Sep 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Dec 27, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
185 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
