The time set does not complete cycle...microwave stops within seconds of set time...what do we do?
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
See if this describes
what's happening:
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
If
it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16
seconds and is a sensor model, it probably has a defective humidity
sensor.
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter,
controller, magnetron, or a bad connection from one or the
other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
