Question about HP 610 Color Copier
I need to now the dc votage required from power
I need to now thedc votage required from power supplly
    Problem Solver:
  • 6 Answers
Input = 100 -240V~ 50/60hz 600ma output=+32V at 350mA & +16Vat 500mA
Posted on Sep 08, 2010
Substitute power cord for a astak cmos wireless camera 818T
Match the DC votage and Current Amps and AC input voltage of the old power pack . Some of the universal Ac - DC power packs have multiple plugs to match the socket on your device.
May 25, 2015 | Astak Home Security
Working votage for harley softail
Hi Anonymous, battery needs to be charged to 12.5 volts or better, charging voltage will be 14.3 to 14.7 volts DC at 2,000 RPM. The control module and other major electrical components need at least 9 volts to function. Good luck
Apr 11, 2014 | 2007 Harley Davidson FXSTC Softail Custom
Need a ac charger for easy grip HD 720p will any charger that fits still charge it
if you find a power supply that fits ,it could work but you got to make sure the votage and power are very close to what the device requires. if you check the device , you should be able to see how much is required and compare the the charger.
Nov 11, 2013 | Televison & Video
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
I have a 1999 RCA TV model # P52921. It completely shut down. It has no sound and picture. I checked the fuse with my tester and there is power coming out of the fuse. I hear a slight, faint, pulsating...
Check SMPS power supply. DC voltages. First check the power supply
bridge/ diodes. Then check DC votage should be 70% rating of the
capacitor voltage. If the capacitor is dry it will show low voltage.
But the diodes should be OK. Check the high wattage resistors
connected in the power supply. There will be a resistor in the
ac input also. Beyond this check all +DC voltages.
Aug 23, 2010 | Televison & Video
Power is plugged in unit will not turn on
This can be a volley of faults. First disconnect the set and using a good multimeter check the continuity from the plug to the mains switch. next check the fuse, if blown check for surge protector short, mains transformer , the dc rectifier, mains capacitor. Check for mains / sub votages. If present then you will need more expertise to check in for failue of active electonics components. If not you are lucky to find the fault within this area. Helpful? Good day
Jul 20, 2010 | Delphi SKYFi3 XM Radio Receiver
I lost the power adapter for my M407 digital camera.
You can purchase a ac/dc adpater with multiple plugs from Radioshack or any electronic store for less than $10. Make sure the votage is 3.3 to 4v that you need. Or you can pay about $30 from ebay. Make sure you take the camera and try the plug on so it will fit in. Good luck -James
Mar 28, 2009 | HP Photosmart M407 Digital Camera
Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
image processor PCB was detected.
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
Aug 05, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
HP 610 Color Copier Logo
23 people viewed this question
Seeker5211
Seeker5211
