Question about Vizio VA26L 26 in. LCD HDTV
Vizio VA26LHDTV10T TV will not turn on with power button or remote. Dead, no click or hum. I have checked the fuse and it is good.
wyoed1
  • 211 Answers
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
freetek
  • 5568 Answers
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Posted on Oct 25, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
phongnv
  • 56 Answers
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
Posted on Feb 16, 2009
Va26lhdtv10t vizio remote
  1. Turn on the component that you want to set up.
  2. Press and release the component key you would like to configure. The red LED will blink once.
  3. Press and hold the "Setup" key until the red LED blinks twice, then release.
  4. Enter the first 4-digit code number for the device you are trying to program. The LED will blink one on each digit entered, except for the last digit where it will blink twice to confirm that a valid code has been programmed.
  5. Now test the code by pressing the "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 3 and use the next 4-digit code listed.
Mar 15, 2014 | Televison & Video
My vizio tv just has the vizio light on when i plug it in it wont turn on
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Apr 22, 2013 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Can i use an rca RCU704MSP2N universal remote for a Vizio VA26LHDTV10T
0048,0028,0016,0025,0061 are the setup codes to check. If you wish to get more codes, 3 digits, five digits etc; check this link. Setup proceedings to some popular models of remote controls is given too.
Feb 25, 2013 | Televison & Video
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
I have a 42" Vizio
Your power supply is dead.
Power supplies can be purchased online for a couple hundred bucks, and replacement is fairly simple and requires only a screwdriver.
For those less tech-savvy, you may want to start saving for a new TV.
Jun 07, 2011 | Vizio 42 in. LCD TV
Only vizio light come on then nothing. have to unplug to turn off
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VA26L 26 in. LCD HDTV Logo
1,052 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
