Question about Sony MDRV900 Professional Headphones
Replacing MDR-V900 headphone pads
Any instructions on how to remove or replace the pads on these headphones?
They don't seem to just snap off like other Sony DJ/Pro headphones.
dj jagged
SOURCE: Repair of Technics DJ headphones
hi dj23 Ive have the same problem with mine but i was lucky to find the screws that undo the headphones their are just behind the right hand side headphone under the black bit that touches your ear theirs 3 screws hiding behind the coving with little arrow marking their they are but be very careful as you open it up as the wires are very bake able in side as their is not much room to get in their to fix them i am still trying to work out the best way to put a new wire on to them as the wire that comes with this headphones are not fixable as its unsleved and its the string in side the outer flex that stops the wires touching each other good luck it fixing them please let me know if you get any other info luck jagged
Posted on Jul 06, 2008
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
mastersaintx
  • 928 Answers
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Posted on Apr 03, 2009
M2Tech1
  • 313 Answers
SOURCE: My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Posted on Aug 06, 2009
How do I fix the 3.5mm plug on a pair of Sony MDR-ZX100 headphones?
This should help:
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
Jul 07, 2013 | Audio Players & Recorders
I need replacement ear pads for Sony cordless headphones model -MDR-IF-140
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Feb 15, 2011 | Sony MDR-IF140 Consumer Headphones
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
Where can I purchase replacement ear pads for the sony mdr-if5000 headphone. Thanks.
If you click my name it will take you to a tip of mine on headphones. At the bottom of it is a link that will help you solve your problem.
Nov 17, 2010 | Sony MDR-IF5000 Headphones
Sony mdr-v700dj Headphones needs new cord! The cord was sliced in half in the middle. The headphones are practically brand new. Is there a way to replace the cord?
All you need to do is solder a new plug on to the end of the remains of the cable coming out of the headphones, then buy an extension lead. It will be much easier than replacing the entire lead, as getting into headphones is a very tricky thing to do.
Feb 10, 2010 | Sony MDR-V700DJ Professional Headphones
Pads on MDR-V300 need replacing
I've found replacement headphone pads at all of the electronic store outlets as well as WalMart, Big Lots, Dollar Stores, Kmart, etc.
Aug 02, 2009 | Sony Audio Players & Recorders
Ear pad replacement instructions for Sony MDR-V6 Headphones
Nov 12, 2008 | Sony MDR-V6 Professional Headphones
Got no sound from the right earphone of my MDR-v500 headphones
It's actually quite easy to open up ... the pad just slips off, and its really easy to get back on and there is a set of three small t screws underneath that just need unscrewing and then you're inside
Jan 27, 2008 | Sony MDR-V500 Professional Headphones
Sony MDRV900 Professional Headphones Logo
435 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
