Question about E-Machines T6520 PC Desktop
One of our network e machine computer keeps restarting by itself with a msg. that the windows has recovered from a serious error. I loaded the recovery disk and picked the recovery of fix the problem with back up. My computer restarted also. now what do I do?
  • E-Machines Master
  • 5,660 Answers
I'd like you to check some components on the motherboard.
Specifically, Electrolytic Capacitors.
More specifically, the one's used in the motherboard Voltage Regulator Circuit.
This is a leading cause of a computer booting up, then shutting down, then restarting again.
eMachines are a budget computer. The low cost, is due to low quality hardware components inside the computer..
Electrolytic capacitors on the motherboard, being some of the above stated components.
1) Electrolytic Capacitors slowly build a charge up, then release the charge all at once.
Akin to a swimming pool slowly being filled up by a garden hose, then one wall of the pool is taken down all at once.
The Electrolytic capacitors used on the motherboard, are aluminum Electrolytic Capacitors, and are Radial in design.
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Viewing the second photo down, at the top right of the page, the bottom Electrolytic Capacitor is of the radial design.
Both leads come out of the bottom.
Essentially, an aluminum Electrolytic Capacitor is a small aluminum 'can', with three strips of thin foil rolled up together, inside.
A) One strip is metal, and is the Conducting strip.
B) One strip is also metal, but has a non-conducting medium applied to it.
C) The last strip is composed of a paper-like material, and is soaked with Electrolytic Paste.
The paper strip is placed between the two metal strips, and all three strips are rolled up tightly, then inserted into the 'can'.
(Of the two leads that protrude from the bottom of the capacitor, one is a Positive lead, the other is a Negative lead.
The Positive lead is connected to the Conducting strip.
The Negative lead is connected to the Non-Conducting strip)
At the bottom of the 'can' case is a seal. This seal is composed of a synthetic rubber-like material, and is a flat disk shape.
At the top of the 'can' case is another seal. It is a thin, flat, disk of metal.
The center of this disk shape has an X, or K, etched partially into the disk.
Electrolytic Capacitors break down over time.
The design manufacturer of a product that uses this type of capacitor, is aware of this, and plans accordingly.
The capacitor used is 50 percent better than is required.
This way as the capacitor breaks down, it weakens to a state that is still usable.
Low quality Electrolytic Capacitors have inferior Electrolytic paste.
As the paste breaks down a gas is formed. (Hydrogen gas)
The gas expands inside the can's case, and slowly pushes the Electrolytic paste out.
(Oozes out)
When the capacitor is starting to break down, the outside can case bulges.
As the capacitor breaks down further, the paste is pushed out of the bottom seal, (Rubber like disk has one side pushed out of the bottom), and/or breaks the etched design on top open, and paste pushes out.
So much paste loss, and the capacitor can operate in a weakened state.
Too much paste loss, and the capacitor fails.
The paste can also dry up inside, and will show no outward visual signs of failure.
Computer unplugged from power, computer case open.
TOUCH (Not 'shouting') the metal frame of the open computer case, BEFORE you reach inside, to relieve your body of static electricity.
[Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power you are safe.
TOUCH the metal frame, and your computer is safe.
Work on a table.
Do Not work on a bed, or directly on a carpet floor. These are high areas of static.
Should you get up, and walk away in the middle of working on your computer, be Sure to touch the metal frame upon your return]
See if you can observe visual signs of capacitor failure.
http://www.capacitorlab.com/visible-failures/index.htm
A video showing the results of capacitor failure, in the motherboard Voltage Regulator Circuit,
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
Part of what the motherboard Voltage Regulator Circuit does, is to regulate voltage for the Processor.
The Processor must have a steady, clean, supply of voltage, and the voltage must be within a certain range.
Too much, or too little voltage, and the Processor turns off.
(BIOS turns the Processor off)
Failing Electrolytic Capacitors in their weakened state will charge up, and release for a brief time period, but then will break down.
This is why the computer comes on, then shuts down.
Replacing the motherboard is the solution.
One more 'ailment' may apply.
It could be Electrolytic Capacitors in the Power Supply, that are breaking down.
Test the Power supply voltages, or replace the Power Supply with a KNOWN to be good, working unit that is compatible, for a test.
(Compatible being the Power Supply is the correct size, and shape, plus also has enough Wattage, and the correct amount of power cables, plus the correct power cables)
To test you will need a multimeter, or a power supply tester.
A computer (Personal computer) Power supply puts out three main voltages.
A) 3.3 Volts. (Wires with Orange insulation)
B) 5 Volts (Wires with Red insulation)
C) 12 Volts (Wires with Yellow insulation)
If the 12 Volt power rail is 11 to 13 Volts, the power supply is okay.
Below 11 Volts requires replacing the Power Supply.
You can post additional questions in a Comment.
Posted on May 26, 2010
  • 324 Answers
There is a problem in your operating system you need to reinstall the operating system while reinstalling it ask for repair please select that it will work
Err msg "windows unable to complete installation. to install windows on this computer, restart the installation."
Order the CD from the manufacturer or you are going to have to download a program to wipe the active partition (c)
Jul 21, 2013 | Gateway Computers & Internet
How do i fix error ofoo:0244 and ofoo:1a44 (msg block 16867582, 46028639 & 111595250), please? I get these codes when I start my pc
I would suggest you first try the Start Up Repair for Windows XP.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.
2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.
3. When you see the blue screen, let the computer load everything and when it's done choose "To set up Windows XP now, press ENTER"4. Press F8 to agree to the License Agreement 5. Choose "To repair the selected Windows XP installation, press R"
Windows will then start the repair process. Do not worry all your data and settings will be retained.
If above solution does not work then,Use Recovery Console.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.3. When you see the blue screen, let the computer load everything and when it's done press R to repair Windows XP using Recovery Console4. On the Recovery Console, choose the installation you would like to log on to (for example c:\Windows)5. Type Chkdsk /p /r on the Recovery Console and your computer will begin to check the hard drive for error and recover data.6. Once Chkdsk is completed, type exit then press Enter. Computer should restart. No need to boot from CD at this point. You can take out the Windows installation CD.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Microsoft Windows XP Home Edition
Windows explorer (windows 7) keeps on stopped working and restarting every second
Windows 7 Restarting maybe because of serious computer errors. If you see a blue screen error message for a few seconds before the computer restarts then this is likely to be the cause then it might be a hardware error.
Jun 07, 2011 | Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Blue Screen then system restarts with an error message
There are two possible solutions given by Micrsoft, one & two.
Both explanations are extremely, but about halfway down each page is the Resolution; One requires a registry edit; Two has a Windows Update you can download.
Dec 23, 2008 | Microsoft Windows XP Home Edition
Installed a video card xfx on windows xp pro now computer shut of
its a normal process when you installed a new Video Card. the only problem there is, if its not compatible with the chipset of your main board. it will create an error and slow down your system/computer later on. to check it, see the manual of your main board and find what its chipset.
Dec 17, 2008 | Acer Aspire T310 PC Desktop
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Asus bios problem
Go into bios and set to default and restart check if message still appears if not go and rest to suit CPU etc
Aug 27, 2008 | ASUS P5PE-VM Motherboard
Problem with windows xp service pack 2
Windows was unable to save all the data for the file drive_letter:\file_path\file_name. The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.To restore normal behavior:
1. Open a CMD.exe window.
2. Type the following command and press Enter: REG ADD “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\3ware Storage Controller” /V CacheControl /T REG_DWORD /D 0 /F
3. When you receive the The operation completed successfully message, shutdown and restart Windows XP.
Apr 18, 2008 | Computers & Internet
E-Machines T6520 PC Desktop Logo
247 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
