Question about Kenmore Oasis HE 27082 Top Load Washer
Our kenmore washing machine is turning on by itself, so we are having to keep it unplugged when we are not using it. what should we do?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@#
Posted on Sep 30, 2010
I keep getting a SUD error, I have stopped the cycle and reset by unpluging the washer, it keeps showing the SUD error. What should I do?
This code indicates that an apparent sudsing condition is detected. It happens when a non-HE detergent is used. Run a cycle without detergent or allow the machine to fill then drain it to make sure suds are removed. The problem is in draining if the code still flashes even no detergent is used.
Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Kenmore machine is made by Whirlpool and therefore troubleshooting is basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
Jul 20, 2011 | Kenmore Elite HE5t Washer
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite Oasis HE will not turn on.
thus your machine electronically activated (bush bottons/ digital lcd reading) If yes try to :
1. remove all the loads including the water
2. Unplug it
3. rest it for 12 hours until the electronic will reconfigured itself.
if the problem still exist, Trace the wire from the plug all the way inside the machine (open the back where you can have an access to the motors) along the way you will a "FUSE" check it , see if it is not busted. If busted then replace it, before doing this thing make sure you UNPLUG the unit
Nov 08, 2009 | Kenmore Washing Machines
Water level won't fill past the lowest setting.
you may need to replace the level selector switch itself... if it has a reset option ( usually near the large side of the button, w/it plugged in, turn the switch all the way to reset, unplug the machine and then plug it back in. ) this has been known to work on occasion....hope this helps
Oct 18, 2009 | Kenmore Washing Machines
Door went ajar while in wash mode and now the door won't shut
Unplug the machine, computer should reset itself. Check if the door opens when the power is turned off.
Good luck dirtdoctorjak@aol.com
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore HE2 Plus front loading washing machine that is about 2 1/2 years old. It just started turning on and then off again, all by itself. Last night we ended up jut unplugging it. And when I...
Most likely it is the timer/control board.
It is a plug and play swap-out, but the tricky part is getting TO the board :D
Only you can determine if you have the skillset to attempt the repair - however without properly testing the components - you may just end up throwing $$ at the machine replacing good parts and still not find the problem.
This type of repair is best left to experienced repairmen. You will SAVE money in the long run.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore HE2 Plus Front Load Washer
Water will not drain from machine
one of three thing is happening,lid switch is bad,the motor coupler that turns the water pump has broken or the water pump itself is broke or clogged with somthing,you can check the lid switch buy lifting and closing the lid slowly to see if you hear the clicking sound,to remove cabinet remove the 2 head screws one on each side of head,flip up,use a screw driver two remove the 2 spring clips one on each side under head,unplug lid switch,tilt the cabinet toward you and pull it off,you now can check the water pump and motor coupler,let me know what you find-mike
Apr 08, 2009 | Kenmore Washing Machines
Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Feb 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
