Question about GE GSS20IEP Side by Side Refrigerator
Ge rifrig will not defrost
I have a ge gss20 side by side that will not defrost, The heating element went bad and I replaced it, put the terminator in my deep freeze on it is closing. When I frist got the refrig, a ge tech came out for a moisture problem and replaced the fan, circuit board, door gasket, And some other stuff, (he was a parts changer) so I reinstaled the old circuit board but it is still frezzing up. I don't want to say its low on freon because after I defrost it, it will work for about 10 days before it frezzes up again. The new heater is comming on (I can see where it has dicolored the glass tube) So I am at my wits end with this thing. TIA, Jack
    Genius:
  • 1,073 Answers
You have a defrost issue not being able to verify circuits on the mother board i would replace the high limit, what you are calling the termination stat this stat stays closed unless the temp hits 140, thats right 140 degrees f and change the evaperator sensor.
evap sensor can cause missed defrosts or no defrosts
high limit part number wr50x10068
sensor number is wr55x10025
each part is 7-15 dollars each
Posted on Apr 10, 2008
Freezer coil freez up
its most likely the defrost heating element as G.E. is notorious for a poor defrost heater,you need to remove the inside rear panel in the freezer and this element is located at the bottom of the evaporator core,you can test it with an ohmmeter,its in a glass tube and if bad will pull apart,be careful of broken glass tube,the new heater is a dual tube G.E.# WR51X10101,it uses 2 tubes side by side,it will fit like the original,the only thing you need to do is route the longer pink or blue power wire down the opposite side with the other power wire because there will be a jumper wire on one side of the new heating element,very rarely does the defrost terminator go bad,if it does,to test it it needs to be below 15 degrees to test good as this is a bi-metallic switch and closes below 15 degrees
Aug 26, 2012 | GE Refrigerators
I have an older GE Profile side by side not defrosting, have continuity in element when warmed thermostat kicks off and I have replaced the timer, still not defrosting. Model #THP21PBSMWW S/N SL238841
Need to check and see if the element is heating up when it goes into defrost. If the thermostat is bad it will not go into defrost. I purchased a new heating element for my GE and it came with the element and thermostat together. Also make sure the fan is running in the freezer this moves the heat through the coil as well as the cold temp when in freeze mode.
Nov 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Problem with the unit not defrosting. How do I know which part is the problem? Thermostat, heater and Bracket assembly or mother board. Is there something else I should be looking at? Thanks Dan
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Adaptive Defrost Control Bad?
If there is no continuity on the heating element, it is BAD. Replace the heater and the defrost thermostat at the same time.
Aug 02, 2009 | Maytag Refrigerators
Not working found broken defrost element
you have to use the heavy duty heating defrost elements on ge frigerators
Mar 21, 2009 | GE GSH25JFR Side by Side Refrigerator
GE dryer tumbles, but there's no heat
Hello coylejm, Thank goodness, 220v has a BAD reputation. Your hunch is correct. To confirm use a DVM to check the heating elements conductivity. Open one terminal of the element and measure ohms of the terminal. A very unlickley chance you damaged the control box. Merry Christmas.
Dec 13, 2008 | GE Profile Harmony DPGT750EC Electric...
DEF appears on freezer door and freezes up.
deF error means that you need to defrost the unit. Leave the unit unplugged overnight and defrost completely.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS20IEP Side by Side Refrigerator Logo
404 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
