Question about LG Vu CU920 Cellular Phone
My phone's touch screen isn't reading my touches right. when i click on the bottom buttons (menu, phone, etc) they work. But when i click on the top part (message center, or any of the buttons on the side of the menu ) won't read at all. I want to check messages but i can't get in there .
  • 131 Answers
Hope this helps try calibrating the screen
Posted on May 28, 2010
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
Printscreen not working ipad
To capture screen shot or print screen on your iOS (iPhone, iPad, iPod touch):
1- Press and hold menu button (the menu button at the bottom of your device)
2- While the menu button is hold down, press the power/lock button (the button that you use to lock the screen at the top of your device) Read more: How to capture screen shot or print screen on ios iPhone, iPad, iPod touch ' loymovie
printscreen-not-working-ipad-fsa0em3gpfye3khtm1m3hcbs-2-0.jpg printscreen-not-working-ipad-fsa0em3gpfye3khtm1m3hcbs-2-2.jpg
How to capture screen shot or print screen on ios iPhone iPad iPod touch...
Jan 10, 2014 | Apple iPad Tablets & eReaders
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
My samsung tocco lite touch screen wont work only the buttons and the camera button work i try and touch something on the screen and if it is at the top of the screen it will move if i touch by the bottom...
same thing happen's to mine, and i'v only had mine for two months :O aha, although i believe it's 'cause i got the screen wet, i mean it's happened before but, usually worked but, this time i think that the water dissolved into the phone making the touch screen not work, mine's still not fixed but, trying taking the phone apart and re-building it. That might help. Kayleigh xx
Jan 15, 2011 | Cell Phones
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
How to do a hard reset on sprint samsung seek cell phone
Software reset Samsung Seek M350: -From the Home menu screen , touch the Main menu tab, located at the bottom
-Touch Settings
-Scroll down to the bottom of the menu
-Touch Reset
-Touch Reset Settings
-Read the statement displayed then touch Proceed
-Enter the 4 digit number then touch Done
Hard reset Samsung Seek M350:
-Touch Settings
-Touch Reset
-Touch Reset Phone
-Enter the PIN then touch Done to confirm the Phone Reset
Your Samsung Seek M350 will run quicker after resetting it. You can check it, hope you like my work.
Good Luck and please rate 4 thumbs up for the free answer
Sep 22, 2010 | Samsung Cell Phones
How to edit my contacts on my iphone
On your iphone touch contacts, then touch the contact you want, then touch edit at the top right of screen. Edit your info and then touch done at the top right of screen. Next open up itunes and then plug your USB cord up to the iphone and computer ports and wait for the ipod to show up under the devices on the left side of the screen. Then click on the ipod icon that shows up under devices at the left of the screen. Click on the info tab at the far right on top. Make sure the box is checked that says "Sync Address Book Contacts" Underneath that heading click on sync all contacts. Then click on Sync at the bottom right of the screen. Give the system a few minutes to do its thing and it will tell you on the computer screen when it is done syncing.
Jan 26, 2010 | Apple iPhone Smartphone
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
The language is in chinese
This is how you correct the problem.
1) Make sure there are no games in the DS
2) Turn on DS
3) At the splash screen touch the touch screen to access the main menu
4) At the main menu on the bottom there is an icon that looks like the DS opened. Click on this ICON
5) After Clicking on the icon you will appear at a menu that has four icons at the bottom. Click on the first one on the left. Should look like a wrench
6) Next touch the icon that looks like a globe from there if you can not read the word the top left cornner is the button for english.
7) Touch that button in the upper left cornner and touch the bottom (very bottom that has A or B) click. This should automatically change the words to english. This should fix the problem
Feb 25, 2009 | Nintendo DS Lite Console
Samsung U700 how to change the language from Chinese to english
for those people who are like me and cannot read any asian at all must follow these steps after you have successfully placed the new firmware on your phone.
the center button is now the menu button, it is no longer the left top touch button
so go to the menu, then to settings which is the bottom right or the 12th icon on the menu screen
the 4th down in settings is PHONE SETTINGS and the first of those is language lol
english is the second language down, and after you do this you will now be able to navigate through yourself :)
but the first time it won't want to write in english, but this can easily be fixed, the top right touch button just needs to be clicked and moved down to either ABC or T9Abc... ect whichever one you think you will need
Apr 29, 2008 | Samsung Cell Phones
LG Vu CU920 Cellular Phone Logo
163 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
