Question about Lexmark X73 All-In-One InkJet Printer
I can't print
The printer makes a noise like slipping gears. The paper starts to feed, but doesn't get far.
  • 2 more comments
  • Anonymous Apr 08, 2008
    Yes. I have the same problem. Please notify me when you find the solution. Thanks!
  • Curt-eous Apr 08, 2008
    The top page feeds part of the way then stops. Clacking sound like slipping gears.
  • blow me Apr 16, 2008
    I have the same exact problem...paper starts to feed clacking slipping gears
  • Anonymous Apr 30, 2008
    yes i received this printer with my computer in 2001 and love it.
    installed it with my 2006 windows xp computer and it's been working great
    until the grinding noise and paper starts then nothing.
Mine makes a noise when turning it off and on and then the light just blinks. The paper does not feed at all. Nothing works! And I've never really had a problem since getting it many many years ago...
Posted on Apr 14, 2008
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Makes noise when loading paper
My Carriage Return Belt is frazzled and about to break. Where and how can I get a replacement for this thin but until now strong belt? I'm quite sure I can put a new on myself.
Apr 22, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Noise
The only real common noise on that machine that I can think of is in the tray 3/4 module. When it goes to feed paper there is a gear chain that looses mesh and makes noise, doesnt feed paper , just shuts off.
Other than that, I have not seen many noises from that product.
Mar 28, 2009 | Xerox WorkCentre Pro C133 Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Printing
Does it feed a length of paper? if so, you may have either the wrong paper, or the paper loaded incorrectly. It needs to be thermal paper, and it will only print on one side, so if you are sure its thermal paper then try turning the paper over and loading it that way.
If it doesnt feed any paper and just makes noise then the problem is probably a broken gear inside the printer. For this you would need to find a place that can repair these terminals.
Nov 06, 2008 | VeriFone (M19755014US1) Magnetic Card...
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Won't feed paper
when you say ''heavy weight'' do you mean thin card etc.
Most printers dont like to use thicker paper. does it make a noise. like gears slipping or crunching when it is trying to feed. if this is the case, then the feed gears maybe worn.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X73 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
