Question about Garden
I have a white outdoors riding mower....the mower shut off when i engage the pto...is the switch bad?.....can i by-pass it?....how do i test the switch????
  • cherieager May 27, 2010
    i already by-passed the switch under seat...the mower just shut off when blades engage...
  • 3 Answers
Check the safety pressure switch under your seat. When you engage the PTO and get off the lawn mower, it will kill the engine. I had the same problem; drove me nuts. I thought it was the switch that is compressed when the PTO is engages. It wasn't. It was the safety under the seat. Bypassed and it worked fine. Ordered a new switch from a local repair shop. Good luck.
Posted on May 26, 2010
White riding mower problem,while setting in the seat you start too release the mower height handle to engage the mower but it kills the engine. can someone give me a idea whats wrong
Posted on Jun 12, 2010
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
Engine runs, but when I engage the electric PTO why does it go dead?
Newer mowers have a safety interlock that prevents the mower running when going in reverse. My guess is that the reverse switch is on and when the PTO is activated the engine dies like you shut off the key.
Second idea is that the device the PTO drives is frozen up. Test this by trying to see if it turns with the engine off. When you engage the PTO the engine chokes down because it can't turn the PTO.
Mar 29, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
What causes mower deck to sometimes engage after PTO switch gets shut off.
Sounds like a bad connection in the wiring harness from the switch to the PTO clutch. I have a lot where the wires broken at the clutch but still make contact randomly since the insulation was still in place.
Aug 11, 2014 | Garden
Why does my John Deere 5425, Pto keeps shutting off?
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
May 12, 2014 | Garden
As soon as ignition key is turned to run PTO engages
check your pto switch with a test light turn pto switch to off take T/ light ground it good turn ignition on and if light comes on you have a bad pto switch
Mar 17, 2014 | Garden
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
338 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
