Question about Samsung Cameras
My Samsung Camera L301 have white screen when i press power on
I have a Camera Compact Samsung L301.But when I turn on, it only have a white screen. Its Lens is normally.
Any one can help me?
SOURCE: White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Posted on Apr 05, 2008
SOURCE: Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Posted on Sep 18, 2008
  • 291 Answers
SOURCE: what does format mean on a samsung l301 camera?
Formatting is erasing the memory card and preparing it to take new photos. If you haven't saved the photos to your computer yet, you will need to find a memory card utility that "rescues" data (pictures, in this case) from a card. You can go to your card manufacturers (Kingston, Sandisk, or whatever your brand is) website and find a suggestion for what utility they suggest.
If you had them saved to your computer, no worries, just start taking pictures again!
Posted on Sep 29, 2009
SOURCE: I need to get a manual for samsung L301 camera
i have it ,send me your email adress,i will send it to you,friga12@yahoo.fr
Posted on Jan 21, 2010
  • 11967 Answers
SOURCE: My Nikon Coolpix S3000 is
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 11, 2011
I have a L301 compact. it says on rear screen, card locked. what do i do.
he says that becose your memory card is locked p .....if u dont lock it . just put out the memory card and look at rear has a clip...that locks and unlock the card. Olso chek for a switch that locks and unlocks the card on camera if exists..
Sep 21, 2015 | Samsung Cameras
Samsung camera manual
If they're on a memory card, format the memory card. If they're in internal memory, format the internal memory. See page 49 of the manual: http://downloadcenter.samsung.com/content/UM/200904/20090429105911562/L301_English.pdf
Dec 03, 2013 | Cameras
How do I set the aperture manually on the samsung l301 digital camera
Set the camera to the manual exposure mode by turning the mode dial to "M". Change the aperture by pressing cursor-up/down. See page 19 of this manual.
Mar 01, 2013 | Cameras
How do i set the aperture manually on the samsung L301 camera
Mar 01, 2013 | Samsung Bl103 L201 L301 S1070 Lens Zoom...
SAMSUNG L301 CAMERA LENS STUCK OUT
my camera samsung L301 lens stuck when swicting on
Feb 04, 2011 | Cameras
Power on screen white
lens assembly (barrel unit) struck up. slightly push lens while power off & pull the lens while power on. repeat this 2 to 3 times it will works. dont apply any oil in the barrel unit. but you may use body spray or room spray to solve this issue permanently
Feb 06, 2010 | Samsung Digimax A503 Digital Camera
I need to get a manual for samsung L301 camera and possibly a cd of instructions
Oct 14, 2009 | Samsung Digimax 301 Digital Camera
Screen appears faulty
With switched on try pressing the camera casing around the edges of the screen. This may be a loose connector and squeezing the camera casing may rectify it - then may perhaps it will not. Try the menu button If it comes up look for the Reset function. Carefully look in the manual in case there is an error correction method. Failing all that Get onto the Samsung web site Technical Help.
Jun 02, 2007 | Samsung Digimax A402 Digital Camera
Cameras Logo
176 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
