Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Yellow spots on screen of mitsubishi projection tv 62527
  • Mitsubishi Master
  • 5,138 Answers
Bad light enigine/optical Assy call UED
1-800-648-6657
Posted on May 26, 2010
Testimonial: "Very Helpful because i didn't know what was going on. Thanks"
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
I have a WD 62527. mfg Oct 2005, I have been dealing with this problem for two years. TV wont come on and green and yellow light flash, then just the yellow flashes all the time. I can push the reset...
which LED blinks yellow? that model has a filter in the back that you really want to keep clean. also make sure that the lamp door on the back is securely closed. the lamp door and filter are right next to each other.
Dec 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
429 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
