Question about Jura Capresso Elegance Therm 437 8-Cup Coffee Maker
Capresso model 437.01 leaks while brewing. Replaced the filter, cleaned the machine, replaced the water reservoir twice. The water reservoir broke and I purchased a new one. The machine had never leaked before so I thought maybe the new water reservoir was defective. Capresso sent me a new one. For three weeks I made coffee every day with no problems. It started leaking again today. Two thirds of the coffee brews into the carafe and the rest ends up on the counter. Any suggestions?
  • 132 Answers
SOURCE: My Keurig B70 at our home in Maine worked fine
sure it need descaling & cleaning
Posted on Jun 07, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
  • 13 Answers
SOURCE: How do I disassemble and clean the brew unit motor
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
NewsView
  • 40 Answers
SOURCE: My cuisinart brew and grind overflows onto to the counter also
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your carafe and machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water spots). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
  • 3 Answers
SOURCE: Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Posted on Jul 11, 2010
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
How to reset descale function on Capresso coffee maker
follow this steps and fix it. God bless you
    • 1 Unplug the coffee machine and remove the cup.
    • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    • 6 Unplug the machine and dump the water into the sink.
    • 7 Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Oct 15, 2012 | Capresso Jura-Impressa C 9 One Touch...
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
Water leaking jura s9
The connectors on capresso machines are very tricky.
take it a part again, and make sure all the rings and pressing clamps are in the right place. Also take a good look and "IN" on your hot water tank, and the pressure relief valve in back of machine
Mar 24, 2010 | Jura Capresso Impressa S9 Coffee...
E8 leak
If leaking water from right front when brewing, cleaning or steam then the possible problem is the feed tube from the pressure pump this is mounted with a small o-ring and either the pipe is fractured or the o-ring has perished.
Feb 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
ph 201-439-1700
info@electra-craft.com
www.electra-craft.com
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Jura Capresso Elegance Therm 437 8-Cup Coffee Maker Logo
93 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
