Question about Craftsman 2700 PSI Briggs Stratton Powered Pressure Washer
My lawn mower with a Briggs motor Wont start, has spark fuel is good , the unit is approx 5 years old, but seldom used, worked great last year, drained the fuel, and stored it for the winter.Refueled it and wont start. I can getting started if I pour a little gas down the carb, but naturally it wont run long. I'm thinking needle and seat, any help would be appreciated. Thanks
  • 109 Answers
SOURCE: Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Posted on Apr 16, 2009
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
SOURCE: Lawn Tractor won't start Craftsman LT1000 17.5 OHV
you carburator just needs to be cleaned/adjusted, and if your original fuel filter isnt clogged and looks clean, leave it, but the air filter is a good idea to change at least once a year (grass shavings covered filters dont help the engine much).
Posted on Feb 20, 2010
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
SOURCE: Bought unit new last summer.
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Posted on Oct 13, 2010
Mower can not start
Does it have spark? Does the engine get fuel? If you spray starting fluid into the air filter will it start up?
Sep 20, 2016 | Craftsman 675 Series 190cc 22" Briggs ...
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
We have a briggs and stratton lawn mower that has very few hours on it but has been in storage for the last 5 years, it starts but dies
Clean the gas tank,after a year gas can turn into a gel which will clog the carb,clean the air filter,check spark plug,and readjust the carb(a small screw on the carb
Sep 03, 2012 | Briggs & Stratton Garden
Our Lawn Mower turns over but will not start we put new gas ,spark plug .and battery Help
Lotsa Gas sounds like the float is stuck ? at bottom of carb.remove the float, bowell , clean and try it again !
May 27, 2012 | Briggs & Stratton Garden
I've been trying to start my briggs & straton Masport lawn mower, after it was sitting idel for over a year. Replaced oil ok / added new fuel / spark working, however it dies after fisrt kick...
You probably still have old fuel and water in the carb itself.
take off the air filter and look for the bowl screw or clip *(depending on model)
You can drain the bowl and let some clean fuel run through the gas line as well.
If the new fuel was last years you might want to check the gas can for water as well.
I work at a mower shop and at this time of year we do a lot of these kinds of repairs.
Fuel today just isnt kind to equipment that sits around for any length of time.
Mar 27, 2011 | Briggs & Stratton Briggs Stratton...
I haven't used my mower in a few weeks. It worked fine before, and now won't start. I can't really tell if it's turning at all, or if nothing is starting to begin with. It look a bit low on oil, but I...
You might have an accumulation of water in the fuel tank/carb.
Drain them both and make sure you put clean fresh fuel in.
The gas can might be contaminated too so be watchful.
Check your spark plug too. Remove it and make sure it isnt water or gas fouled. *(wet and not sparking) A fuel fouled plug usually needs replacement. Water...not so much.
Good luck and be careful!
Aug 24, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Cleaned the Briggs & Stratton Riding Lawn Mower's head and valves. Put it back together and it refuses to start, get good starting try, no joy. Checked the spark, great! Checked the gas- great!...
did you usae a new head gasket and clean the old gasket off? does the plug get gas? you must have spark, fuel, compression and timing in order for it to run. also did you gap the coil to flywheel spacing?
Jul 08, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 2700 PSI  Briggs Stratton Powered Pressure Washer Logo
226 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
