Question about Bling Software 123 Movies for PSP
Start-up help "Could not initialize application. Error 42 (IPM) Please contact technical support." This comes up when I try to start the program. HELP.
The printer works fine from Windows including Scanner.When using photocopy from printer panel does not work.
If you are not getting any error messages, I suspect you definitely have a printer hardware problem, especially if it prints fine from Windows. Best to contact Canon's technical support with this one
May 14, 2014 | Canon PIXMA MG3550 Inkjet Multifunction...
""an internal error occurred in the initialization
Hi! Welcome to www.fixya.com.
You can go to this website and follow the instructions
http://support.microsoft.com/kb/929135
Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
SC-810 ERROR E071
hi there
concern ERROR ( E071 ) means Disconnection o motor output connector.
please check the motor output connector for loose connection and disconnection. otherways means IPM module is defective.
if you need more help please contact me.
BEST REGARDS
ASHRAF ABOZID
aabozid@hotmail.com
Dec 24, 2010 | Juki DDL-8700
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
I have just bought football manger 2009 and it installs fine but i cant get the game to load it just comes up with the error The application failed to initialize properly (0xc0150002). Click on OK to...
is the game compatible with your system? it has minimum requirements. what you are getting is a memory error.
try removing the program through add/remove and re-installing it.
Dec 01, 2008 | Computers & Internet
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Scanner
Hi
I found the solutiom from microsoft
1. On the Start menu, point to All Programs or Programs, point to Accessories, and then click Windows Explorer. 2. In Windows Explorer, edit the file type. To do this, follow these steps, as appropriate for the version of Windows that you are running: • For Microsoft Windows XP or Microsoft Windows Millennium Edition, follow these steps: a. On the Tools menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol under the (NONE) section, and then click Advanced. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2007, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. • For Microsoft Windows 98, follow these steps: a. On the View menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol, and then click Edit. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. 3. In Internet Explorer, verify the e-mail program. To do this, follow these steps: a. On the Tools menu, click Internet Options. b. On the tab, change the default mail program to Outlook Express in the E-mail box, and then click Apply. c. In the E-mail box, change the default mail program back to Outlook, and then click Apply. d. Close the Internet Options dialog box. e. Click Start, click Run, type mailto:, and then click OK.
you can also visit http://support.microsoft.com/kb/312346
Hope this will solve the problem
Jun 04, 2008 | Brother MFC-8460N All-In-One Printer
Bling Software 123 Movies for PSP  Logo
123 people viewed this question
Top Bling Software Video Game Consoles & Games Experts
James Wishart
Are you a Bling Software Video Game Console and Game Expert? Answer questions, earn points and help others
