Question about HP Officejet 5610 All-In-One InkJet Printer
I am receiving an error message stating I have an cartridge error
    Novelist:
  • 142 Answers
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00428054&cc=us&lc=en&dlc=en&product=441125
:) Dr Tony
Posted on May 26, 2010
My HP c4580 states that the cartridge is missing or undetected.So I reinstalled the cartridges and it says the samething,WHAT DO I DO?
It's a new cartridge you fitted?
If not, it's probably because it genuinely is empty.
If new:
Remove all the cartridges. Switch off the printer.
Switch the printer off and reinstall the cartridges.
Switch the printer on.
Switch the printer off.
If you continue to receive the same error message it's because the cartridge isn't fitted/seated correctly, or that cartridge has a problem.
Feb 24, 2016 | HP Photosmart C4580 All-in-One InkJet...
Does anyone know if you can purchase a single yellow cartridge for a HP Photosmart B209a 3 in 1 printer. I continue receive error message stating - red, yellow, blue appear to be missing or damaged.
Take out all error cartridge..u find small chip in all cartridges.its counter/ detect chip.clean n make it shiny by wipeit wid Normal eraser.fix back n check if nr. Buy new cartdg
Feb 13, 2015 | HP Office Equipment & Supplies
I've received the error message: "Printer
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
I received an error message that ink cartridges needed replacing. I replaced the ones stated and checked the ink levels on the computer. The report is that the ones replaced are at 100% and the others have...
If you are using refilled (worst cartridges) or third party cartridges then that is most likely the problem.
If you are using factory new HP cartridges, then you need to contact HP to get the cartridges replaced.
Don
Feb 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
I am printing on a Canon Selphy ES1. The media package - ink and paper combined - it has just been replaced with a new pack and I get the following error message on my Mac: "Failed to receive data...
Check "Printer Properties" so that the cartridge is set to color if E-Pxx cardridge is mounted and set to B/W if E-PxxBW cardridge is mounted...(xx stands for number of postcards) // Kjell.sundling@hotmail.com
Jul 14, 2008 | Office Equipment & Supplies
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
HP Officejet 5610 All-In-One InkJet Printer Logo
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
