Question about Canon ImageRUNNER 330s Copier
Need part numbers for upper and lower fusing rollers along with thermistors
Canon ir2000 fusing unit film or top roller
This model has an upper fusing roller & a lower pressure roller.
If you have a print quality issue (that you have narrowed down to the fuser unit) then you will need to replace the upper fusing roller (not an easy job best to replace the fuser unit complete)
Aug 24, 2014 | Office Equipment & Supplies
Di 621 ca
C 0540 Fusing roller (upper roller) thermistor or thermofuse failure.Verify the continuity of the thermofuse ,if neccessary change.The thermistor not defeted easy,90% thermofuse defected.
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Printer leaving toner on page
Verify the fusing unit upper and lower pressure roller,the upper roller thermistor and the oil roller.The toner is not fixing to paper.
Mar 12, 2014 | Minolta DiALTA Di183 Copier
Where is thermistor placed in the photocopier machine
The thermistor is located in the fusing unit in contact with the upper fusing roller.
Dec 17, 2012 | Minolta EP1083 CS/PRO Copier
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower...
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Feb 06, 2010 | Sharp AR-M700N Copier
I NEED FREE USER MANUAL FOR SHARP SF-8100 COPIER
Sharp 8100 file of manual
http://files.mail.ru/N4G1OG
Please vote for me for my answer. Senks) Код ошибки Описание 0 Stepping motor 10 Mirror motor 40 Dark box switch 8 Mirror motor C1 Charge corona C2 Transfer corona C3 Discharge corona CH Interlock or thermal fuse CH possible DV unit not installed properly H1 Heater thermal fuse H2 Thermistor H3 High Temperature H4 Low Temperature H5 Lower thermofuse H6 Lower thermistor H7 High temperature in lower roller H8 Low temperature in lower roller L1 Forward Scan L2 End of Scan L3 Return of Scan L4 PT/main motor L5 Lens L6 Charge block switch P1 Copy lamp thermal fuse U1 Low battery U2 Data transfer U3 Dark box
Sep 14, 2009 | Sharp Office Equipment & Supplies
Service Call 172 Fatal Error
Hi stuart34:
Here is your problem.
Service Call
172: Error
176: Error
High temperature
error detected at
Thermistor.
1) Is the error message displayed?
2) Does the error repeat?
Yes
Yes
Turn off/on the printer.
Replace the Thermistor and turn off the
1 Upper roller 2 Lower roller 1
b
Thermostat Thermostat
Heater Between pins a and b:
Between pins c and d: 231.4kω
Between pins e and f: 231.4kω (at 25°C)
Between pins c and d: 0ω or open
Fuser Unit
a
b
Heater
e
f
Thermistor
c
d
Fuse
e
f
Thermistor
c
d
printer. Leave it for 30 min.
The Thermistors are located in the fuser assembly.
Hope this helps
May 29, 2009 | OKI C9300hdn Led Printer
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Ricoh aficio 1022 all-in-one error code sc542
Fusing temperature warm-up error
The fusing temperature does not reach
the standby temperature within 20
seconds after the main switch is turned
on.
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Power supply board defective
• Poor connection of the fusing unit
It could need a new thermistor
Sep 01, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
75 people viewed this question
old marine
old marine
