Question about Traulsen G20010 Commercial Refrigerator
It doesn't shutdown and it freezes products - Traulsen G20010 Commercial Refrigerator
    Guru:
  • 1,524 Answers
Change the thermostat.
Posted on May 26, 2010
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
Im having problems with my sony erricson wt3i, it suddenly turns off by itself, then i can't access my messages and contacts, its annoying, to think that i just bought this phone.
Download a free Antivir product and check your phone thoroughly: looks like you've got a virus. If that doesn't help (sometimes it doesn't) try to 'Factory reset' and as a very first thing download Antivir which will protect your device
Oct 03, 2012 | Cell Phones
Pee sound as if memory is not working & freezes and says shutdown failure
Ever try opening in the safe Mode and clearing that up? On Bootup press F8 or F5 and choose Safe boot.
Jun 16, 2012 | Dell Computers & Internet
Blue screen on Thinkpad R51e & cannot be shutdown
what operating system are you using and please be more descriptive regarding "blue screen" is it the notorious microsoft "Blue Screen of Death"? or? when this occurs is the system totally locked? or can you hit ctrl alt del and get the task manager? can you boot into safe mode? if you're using xp and can get to safe mode.. have you attempted to restore to an earlier restore point prior to this issue? if yes and you haven't restore back to before issue occured.
May 20, 2009 | IBM ThinkPad R51 Notebook
Magix Movie Edit Pro 12 won't load!
this usually occours when the screen resolution is lower than that required by the program......
try the software at higher resolution or check the system requirements if the video and sound cards meet the requirements of the program.....
May 09, 2009 | Magix Movie Edit Pro 12 for PC...
Acer aspire 5010 bugged fan
as for aspire products, that would be part of the aspire 5000 series.
if your processor is getting that hot often its probably overheating. theres probably some dust bunnies in the fan or the fan pipes. try dusting it out and see if that solves the problems. you generally shouldnt have to alter the fan speeds at all because they are temperature controlled.
try resetting the bios to defaults if some how the fan settings were changed to funny values. it should definately be kicking in sooner than that.
Apr 26, 2009 | Acer Aspire 5000 Notebook
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Restart problem
There might be possibility of Virus.Please check for virus.
This problem may occur if all the following conditions are true:
  • You have East Asian Language support installed on your Windows XP-based computer and the Input Method Editor (IME) selected as your default input language.
  • You have the Welcome screen turned on.
Check weather you are using service pack 1 or above.
If still problem occur then just try to download Shutdown patch from website
Apr 08, 2009 | IBM ThinkPad R32 2658 Notebook
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Traulsen G20010 Commercial Refrigerator Logo
106 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
