Question about Watts Onan Portable Generator - 4000 , Model# 5500
Will not start gas not getting to it
Generator will not start acted like it is not getting gas
  • rev43320 May 26, 2010
    No that is not it gets the gas straight from the regular fuel tank. The tank must have at least 1/4 tank to run the Gen. setting on half tank now.
    Took the line loose just before the Gen. no fuel there, can't find out if it has it's own fuel pump, if it does there should be a fuse to it but can't find one for it.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Be sure to ensure the fuel pump is pumping fuel to the carb by pulling the hose off the carb and watching for adequate flow. A faulty electric fuel pump can often only show symptoms or act up after it is warmed up. Sometimes it may run for 10 or 20 minutes and just shut down. Check for fuel flow immediately upon stalling if this is your symptom. Mine would shut down after 20 minutes and not restart for awhile. I pulled the hose off the carb immediately and noted there was no fuel in the line and it would not pump fuel while holding the start switch on either. If you are mechanically savvy you can disconnect the hot wire the positive wire (red) leading into the fuel pump and connect it with 12 V and see if it pumps fuel out the hose also, but be careful to capture the fuel coming out the hose). Once cooled down it pumped fuel in a weaker than normal stream, but when hot after 10 or 20 minutes it quit pumping causing stalling of the generator. Replaced the fuel pump (and new filter while at it) and everything worked fine again on my 1995 Onan. Much stronger fuel stream noted too from the hose.
Posted on Aug 25, 2017
  • 8,404 Answers
This might sound dumb ... is the fuel valve turned on?
Posted on May 26, 2010
  • 1 more comment
  • A Miller May 26, 2010
    I think the tank is above the engine, it may not require a pump.
    Im not sure on this model.
    Study the fuel line path ... it comes out of the tank ... should go through a valve ... you say it is on ... check it. From the falve it goes to the carb or a pump. Pull the line off ... got gas? Yes ... put it back ... No ... make sure the valve is on ... blow back through the line ... air going into the tank? It may have been blocked.
    Oh? ... my efforts not helpful ... thanks ...
  • A Miller May 29, 2010
    You disconnected the fuel line from the engine and there is no fuel coming out of the line, directly from the tank ... and you are still looking for the pump ... most lines come from the bottom of the tank ... does your?
    good luch with your project.
Low on gas refilled now wont start
If its a diesel then it means it airlocked which can only be solved by calling a mechanic.....
Aug 30, 2014 | Lincoln 03 04 05 06 07 08 Crown Victoria...
Require millivoltage for gas valve on raypack pool heater
clean burn tube to pilot generator replace generator and make sure all wires tight
Apr 12, 2017 | RTO Pressure Switch 3902 Swimming Pool...
My powertrain 6500 model PTG-6500-EXCS won't start. It acts as though it's not getting any fuel. Any ideas?
first check n c do u have any fire at d plug then if so check carb maybe its clog need to be torn down
Mar 24, 2013 | Coleman Powermate Premium Plus 6250W...
My coleman powermate 5000W generator is very hard to start. When I squirt gas in the carburator chamber it will start for a about a minute and then it dies. It acts like it is not getting any gas. I...
The carb. has a nut holding the bowl on.Remove this nut and you'll notice a hole in in it that goes from side to side.You'll also notice one through the center that connects to the other.Make sure these holes are clean.Use a small pin..etc.Chances are it will stay running when you assemble the carb again.
Oct 14, 2010 | Coleman Powermate Powermate 5000W...
Had to tickle the throttle on my yamaha 3500 watt
You should have automatic or manual choke control. Try to find it and open it during start. After that you can close it if stable work is achieved.
May 30, 2010 | Yamaha 4500 Watt Electric Start Generator...
Acts like it is not getting fuel
Check the fuel line to see if it is clear. Run a wire through it or blow it out with air. Then if it is ok check the fuel tank to make sure nothing is clogging the fuel there. (Sometimes over the years debris gets into the tank and can clog there.) Had an old mower that did the same thing you are talking about, start and then quit. Had to clean the fuel tank out and then it ran like a champ. Good Luck
Jun 10, 2009 | Coleman Sport 1850 Generator
Y generator starts but not putting out any power
plug in a electric drill into the generator. start the generator and let it idle. depress the trigger on the drill with the drill set in the forward position and by hand turn the drill in the opposite direction. it should excite the generator and start the drill
May 15, 2009 | Coleman Powermate 5000W Home Backup...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
387 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
