Question about Minolta Maxxum STsi QD 35mm SLR Camera
The shutter speed sounds as if it never changes in any of the modes. Is there a way to test the speed other than the picture quality?
    Brigadier General:
  • 3,006 Answers
Above 1/30th of a second you will not hear any difference due to the way that an SLR camera twin curtain shutter operates.
There are just two tests possible: take the camera to a repair shop for shutter speed testing or just assess the exposures taken when using transparency (slide) film. Assessing the exposure with regular negative film isn't much use as the photo printing machinery can compensate for under or over exposed images.
Posted on May 26, 2010
Testimonial: "Thank you, I will try these things. "
Underexposed images
I hope you received some help already by this time. However, just for other readers shake, your issues has to do with your camera's settings. There are two things that initially determine the quality of pictures and these are:
1. Exposure and
2.Shutter speed
I believe your pictures are dark because settings on your camera feature a combination of fast shutter-speed with a lower value of aperture. Try adjusting those or shoot with a pre-programmed mode under different lighting conditions.
Mar 11, 2014 | Canon PowerShot S51S Digital Camera
I have a Nikon D40 and when it's in M and S mode the shutter stays open for too long and my pictures come out completely white.
What shutter speed(s) are you using? What happens when you use a faster shutter speed? In the S and M modes you are responsible for setting the shutter speed, and you can set it to anything within the camera's range.
Aug 28, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
I just put new batteries in my N65. I haven't used it in a while but it appeears to be working proper, ie the lcd comes on and indicates full battery and the view finder symbols are nice and bright green...
What I'm thinking is the shutter and or the aperture ring is lazy. Move the aperture ring up and down several time see if the little ring next to the the camera body is responding quickly to the change.
Do this without film in the camera.
What I'd suggest is setting the camera in "M" mode aperture at F8 manual set the ISO at 100 and the shutter speed at 1/60 shift the camera into manual focus. The shutter can be in AF-S (single frame with each depress of the shutter). Trip the shutter and listen to it work do that a few times (maybe three) then set the speed at 1/125 do the same test listen the shutter should sound faster. Repeat the test at 250 then 500 then 1000. Then start backing down to 1/60th again, listen to the response. In all manual mode the shutter has to fire it it isn't or the speed doesn't increase and then decrease then the shutter needs service.
Jan 14, 2011 | Nikon N65 35mm SLR Camera
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
How do you change the shutter speed on a Panasonic Lumix DMC-FZ7 Digital Camera? I want to take pictures of lightning with it, I have found the ISO settings find and changed them to what I want, but the...
You may change your shutter speed in Manual mode only. So you should turn your mode dial button to M position. Then you may control both shutter speed and aparture value.
Jun 03, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
Slow sutter speed/Lag in taking a picture
Use full auto mode or take out of Aperature priority, you may be shooting with a very small aperature setting and not know it. Also shutter priority can be set to a slow shutter speed.
Sep 24, 2008 | Fuji FinePix S5000 Digital Camera
NIKON D1X
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
Sep 13, 2008 | Nikon D70s Digital Camera
Minolta Maxxum STsi QD 35mm SLR Camera Logo
77 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
