Question about Hamilton Beach Water Cooler with Storage Cabinet
First the fridge on the bottom does not cool, now the water is not coming out cold. does anyone know what is the problem?
  • Hamilton Beach Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfirst the fridge on the bottom does not cool, now - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 26, 2010
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
konzzz
  • 255 Answers
SOURCE: Bottom not cooling
the blower is broken or frozen.you need to defrost and clean it.or the air passages are clog.
Posted on May 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Posted on Mar 19, 2010
  • 2699 Answers
SOURCE: fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Posted on Mar 22, 2010
Water freezing in bottom of freezer where is it coming from
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have the side by side fridge/freezer and the fridge side does not seem to be working, however the freezer is fine. Would anyone know why please?
heatman101
Jan 26, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
Jun 14, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer quit then noticed fridge side not cooling
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Aug 25, 2006 | LG LRFD21855 Stainless Steel French Door...
Hamilton Beach Water Cooler with Storage Cabinet Logo
548 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
