Question about Coleman Grilling
Need to replace coleman part 5010000563 Regulator Assy.
2 Suggested Answers
csmock132
  • 4669 Answers
SOURCE: The window on the front drivers side door of my 04
You do have a bad regulator but I'm not sure if you need any special tools. I don't think so. You might need a drill and a rivet gun.
Posted on May 03, 2009
Need a new regulator assy where do i get one
Despite being a discontinued model, there are some parts still available for it from Coleman.
Contact their Customer Service Dept 800-835-327. The part # is 9931-5651
I hope this helps you find the part you need. Please let me know. Thanks.
Jun 19, 2011 | Coleman Propane Grillin Griddle 9931-750
Need to replace front right door electric window
Remove door panel, Locate either bolts or 1/4 in rivets holding regulator assy. in the door. remove window mounting bolts, (should be 2) then drill out the rivets and carefully remove regulator with motor attached. BE VERY VERY careful in the next step!!! find a way to lock the regulator assy in position so it will not move. if it flops it can remove a finger so BE CAREFUL! most shops will charge an hour or an hour and a half to do it so if you are not comfortable, don't do it. If you are drill the rivets (3) holding the motor to the regulator and install the new one with the screws provided. reverse for assy.
Sep 01, 2009 | 1991 Chevrolet S-10 Blazer
My knob assy (137-0001) keeps popping off and air leaks around the adjustment knob on the top of the assembly.
SOMETIMES YOU CAN TIGHTEN THE OUTSIDE OF THE REGULATOR UP A LITTLE. OR THE REGULATOR IS BAD. OR THE REGULATOR IS SEEING BACK-PRESSURE JUST AS IF IT WAS INSTALLED BACKWARDS. DO YOU HAVE IT CONNECTED TO ANOTHER COMPRESSOR DOWNSTREAM THAT COULD POSSIBLY BE A LITTLE HIGHER PRESSURE AND BLOWING BACK THRU THE REG. HOPE THIS HELPS, JODY
Aug 27, 2009 | Coleman Powermate 11 Gallon Air Compressor
Need printed circuit board for coleman 8333-8715 need part number have 115 vac to board but no out put
Is that # off upper unit or ceiling assy? Need ceiling assy # Here's a link for you to try.
http://www.rvcomfort.com/rvp/service/model.php
Jul 12, 2009 | Coleman Mach III Air Conditioner
Need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Jun 26, 2008 | Grilling
Grilling Logo
367 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
