Question about Maytag MER6772 Gemini Electric Kitchen Range
My 2002 Maytag Gemini Mer6872 glass top cooking elements persistantly ascends and descends while cooking no matter what temperature I set it at. It does it with copper bottom cookware or with flat cookware. There is nothing in my manual that says anything about that. As for cookware....it says use flat cookware. It has done that since I bought it and I assumed it was normal. I love the stove. Also, how much will it cost to replace the glass top if it should brake.
SOURCE: Maytag Gemini Stove oven will not come on get a code F1-1
Put in a new thermastat in the top oven and it works great. Thanks for the advice(from other's having problems).
My Maytag was older than I thought, so the thermastat was not available on line, but found one at a repair shop that worked. Thanks!
Posted on Jan 12, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
SOURCE: I have a maytag Gemini electric stove. i was just
It means lower oven latch problem, check for obstuctions or replace door latch.
Maytag stove repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
SOURCE: CERAMIC COOK STOVE TOP CRACKED
the same thing has happend to me... same stove.. Maytag Gemini double oven ceramic top. Can i still use it? is it safe?
Posted on Mar 17, 2010
Lower range will not come up to temp on 'bake' after 2 hours it only got up to 275 o but it got to 450 in 15 minutes on broil. This is a sudden thing as it was fine last night.
either the bake element in the lower oven has what is called a "hot-spot" a discolored area on the element and can no longer pass enough current to heat the oven and will most likely burn out soon,or a thermocouple went bad that senses oven temps,but this bulb in the roof of the oven normally goes bad over a matter of time
Feb 12, 2011 | Maytag MER6872 Gemini Electric Kitchen...
Back burner doesn't work looking to remove and
These burners are very simple to replace. Is yours a glass top or does it have coil elements on the top of your stove?
Either way, we can direct and guide you to complete this repair.
You will need to contact us with your model number and we can tell you exactly how to remove and replace the element. When you get your parts from us, here at Accurate Appliance & Parts Supplies, we send complete instructions when when we send the parts to you.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday.
We hope to get you cooking again soon and look forward to working with you. Thanks, Ella
Nov 21, 2009 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Gemini electric oven; glass top cracked
yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Feb 11, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
117 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
