Question about Acer Aspire One Netbook 8.9" Notebook
When turning the computer on it wont load and restarts
It gives you options to go in safe mode or normal mode but none work and it just restarts.
    Guru:
  • Acer Master
  • 468 Answers
It may happen due to hardware failure, BIOS mismatch or due to static
charge. Let us try the basic troubleshooting. Turn Off the Netbook, remove
all the devices attached to the computer, the power cable and battrey, now
holdon the power button for 15 secs (make sure adpater and battery are
uplugged) it will drain out all the static charge. Now, restart the computer
and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click
"Yes", if you are prompted) and then press F10 (Click "Yes", if you are
prompted), it will restart the computer. If still it is not booting to normal
mode, then we have to perform a full system recovery & it is a distructive
process as you will loose all the datas on the computer. To do so, Turn Off
the computer, now as soon as you hit the power button, keep on holding
"AltGr" (it is on the right side of the spacebar key) & keep on tapping "F10"
key, i.e AltGR+f10, it will open the recovery console, select full factory
restore and follow onscreen instruction. NOTE: This will erase all the datas
on the computer.
Posted on May 26, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
Hello, I have a question about my computer. Well today i started up my computer and it tells me that it stopped responding or restarted unexpectedly. Then it tells me to run the computer in safe mode,...
hi,am ravi here,you can just select safe mode and run your system it will solve all system errors and will get open win xp os.after that you can restart and run it in normal mode.you wont get destroied any of your data.
Sep 21, 2010 | Computers & Internet
When i switch my laptop on the following options are showed. launch startup repair, starts windows normally none of them work. what should i do?
Try restarting the computer and hold down the F8 key while the computer is booting, You should get an option to boot into safe mode, Select safe mode and see if the desktop loads. If it does then run system restore (Start, All Programs, Accessories, system tools, system restore) and restore the computer to an earlier state. Well i hope this helps.
Jun 24, 2010 | Acer Aspire 6920 Notebook PC
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
My system wont boot gives me options restart in SAFE MODE SAFEMODE WITH NETWORKING and LAST KNOWN CONFIGURATION OR NORMAL WINDOWS THEN COUNTS DOWN FRON 25 THEN LOOPS OVER AND OVER
when u power up the computer press F8 key then select safe mode with arrow key thne enter in "safe mode'
then go to start menu run type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.
Jun 12, 2009 | IBM (01K6743) 350-Watt Power Supply
Help :( i can't start up my laptop it wont let me :(
what i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Dec 16, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer Aspire One Netbook 8.9" Notebook Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
