Question about Samsung SRS20DTD Side by Side Refrigerator
Why is the temp. light blinking on my Samsung refrigerator?
What does blinking temp bar lights mean on RS261 side by side. No response from display
It is telling you the temperature is out of range. Put a thermometer in it and it should be below 40F 4.5C and above 32F 0C.
Nov 13, 2014 | Samsung Refrigerators
I have the samsung Rs2533sw/xaa. 2 nights ago, we turned off the kitchen breakers to install a light and ever since we turned on all the breakers again, the refrigerator has not been operating properly....
Sounds like you just need to do a reset, press and hold the top 2 buttons till it flashes then let go. If you hold it to long it will run a diagnostic mode and may lock up on a blinking light. The blinking light is a trouble indicator for the service tech. It tells them what sensor or heater is faulty or will point them in the right direction. I found a repair manual on the online auction place E b a y that can help you troubleshoot further but have not bought it as of yet. I just purchased my Samsung and was reading some reviews to see what kind of problems i may run in to.
Jan 01, 2011 | Samsung RS2534 Side by Side Refrigerator
Strange code on temperature panel, blinking 88 88/A8 w/no respons
Press both power cool buttons at the same time, until you here a chime (about 3 sec). This should solve the problem.
FIT FiNallee
Dec 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
Jul 14, 2009 | Samsung Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Our samsung RS267BARB fridge's light is blinking and feels warm
If you cannot reach the plug, then turn off the breaker that feeds it in your electrical panel; most electrical codes require a separate power feed for refrigerators.
Sep 02, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
1,275 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
