Question about Refrigerators
GE TFX27ZF REFRIGERATOR. FREEZER IS OK BUT OTHER SIDE TEMP OF 55 DEG F.
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorGE TFX27ZF REFRIGERATOR. - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 26, 2010
Ge freezer temp changes from -3 to 44degs and the ice melts and runs on the floor. I replaced the main board about 2 yrs ago, help?
Self defrost mechanism appears to be ok sinc eyou can get down to -3 degrees. The culprit in this refrigerator is the temperature regulator or electronic thermostat in this box. It should not allow the temp to swing that drastically from one extreme to another.
Mar 17, 2015 | Refrigerators
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hello, refrig is getting warm 57 deg, the freezer side is ok what now
chaeck the temp of that room where you freege keep.
it can be chaces of high condensation
you put much more hot or warm products accros the limit
if in your freeze has a water heater and it continuous on with out signal of the solenoied valve
comp over heat
lake of refrigerant
Feb 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrigerator compartment to cold
Set both settings at 5 and see if it starts working right
Jan 20, 2010 | GE GSS25LGM Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
