Question about Saeco Caffe Charisma Espresso Machine
Does not start
The machine does not start up. The coffee lights keep blinking and the water button is red and does not change. It does not react to anything.
  • 1 more comment
  • zkapas May 26, 2010
    Please see if your solution is the same - clean out the flow meter and if yes, please let me know what the flow meter is (how it looks), where to find it and how to clean it. Thank you.
    PLEASE let me know what the flow meter is !!!!! I can not clean it if I dont know what it is, how it looks and where to find it. ..
    Please give me a solution to hit problem.
  • 4,737 Answers
The Steady Red light indicates that your Water Tank is not properly fit. This could be because of the Drip Tray full problem. Turn off the machine and please remove the drip tray and put it back after the light changes. Good luck does not start - f768464.jpg
Posted on May 26, 2010
  • 2 more comments
  • Lebanon Raingam
    Lebanon Raingam May 26, 2010
    Here's the picture of the flow meter:
    I hope this helps you.
    I've done that several times and nothing changed. Do you have an other suggestion?
    it did not changed anything. Can you think of an other way?
  • Lebanon Raingam
    I don't know whether you've checked the Drip Tray or not. If not please do it. You can try while it is still power on and verify after you leave it outside for few minutes. I've tried my best to fix this, but there's no more solution from my site. If you would like to give another try, please refer to this site and download all the necessary manuals (Repairing and maintenance manuals, schematic)
    http://www.partsguru.com/MaintenanceofEs...
    Please let me know if the problem still persists.
  • 881 Answers
Check to see if the water level is adequate.
    Are you kidding me? I did not pay for this kind of "advice" - just that you say something, so I'm answered and out of your way... I've checked the water lever, the coffee, everything. I've tried "cleaning the lever meter" - as other "experts" recommended - it was VERY hard to reach and did not help at all... Any other suggestions?
  • 668 Answers
You need to clean out the flow meter in the unit. You have to take unit apart to get to meter and you need to check hoses for any build up and you need to clean it as well .
Hope this helps .
    Brigadier General:
  • 3,917 Answers
Hi
You need to clean out the flow meter in unit. You have to take unit apart to get to meter. Once you clean out flow meter, the machine worked perfectly.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
    Ok, please tell me what the flow meter is where do I find it and how to clean it. Thank you
When I press the button to make a coffee, the light starts blinking like after startup, but nothing happens
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 08, 2016 | Coffee Makers & Espresso Machines
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
How do I reset my delonghi ec860
my coffee machine is not working,,, the water ligh is blinking green n not doing anything.. anyone can help with this?
May 18, 2012 | DeLonghi EC Coffee Makers & Espresso...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
The red Water warning light keeps blinking,even there is enough water supply.
It means ventilate, purge the air out of the system by turning on the knob, the pump should run .Keep it running until the red light stops blinking.If not there's a blockage in the line.
Jan 23, 2010 | Starbucks Saeco Italia Digital Barista...
All leds flashing, after cleaning program
unplug it.... for about ten minutes or so
Mar 18, 2009 | Solis Palazzo Espresso Machine
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
77 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
