Question about Casio Exilim EX-Z750 Digital Camera
Lcd display must be replaced
Seems like a simple process to replace. Removing all screws and gently opening the case. Setting new screen and ribbon cable.
Are there hidden dangers and/or difficulties?
Is this diagrammed any where?
  • Henry Hill
    Henry Hill May 26, 2010
    Thanks, this was a very quick answer.
  • 10,594 Answers
LCD replacement is easy and no hidden danger involve, process is just like as you mentioned.
Service Manual of Casio EX-Z750 has exploded views and disassemble procedure with other technical details and you can download copy from HERE for small fee if you need that.
Hope these info will help you.
Thanks.
Posted on May 26, 2010
Cracked screen has caused a massive black blob across screen. Need to buy a new screen..
I am so sorry to hear that! I've had to deal with a broken screen or two before myself. What you'll need to do is search for your computer model's screen. They usually run about $100. After that, you can either contact a professional to do the work for you, or you can do it yourself.
To do it yourself, you will need a Philips and flathead screwdriver. BEFORE YOU DO ANYTHING, remove the battery and hold the power button down for 5 to 10 seconds. This will discharge any remaining power from the laptop, so you don't harm your computer. There should be four little pads in the corners of the screen case. Remove these, and unscrew the screws underneath. This is where you will need the flathead screwdriver. Gently pry the front of the case from the back. Once the case is opened, unscrew the housing of the LCD itself. There is a ribbon that connects the screen to the motherboard. Gently remove this. Now, just do everything in reverse, with the new screen. Put the ribbon in the new screen. Replace the housing and screw it back in. Then, replace the screen case and screw it back together. Put the little pads back on and replace the battery. Turn on your PC and marvel at your handy-work.
Hope all goes well! Thank you for using FixYa!
Jul 19, 2011 | Computers & Internet
Broken screen, can it be repaired?
The short answer is yes.
It may not be worth it to have it professionally repaired, but if you can do it yourself; it's relatively simple and saves a good amount of money. Replacement screens can be found for as little as $20 dollars on internet auction sites.
Assuming you have a fairly decent mechanical ability:
1) Remove battery and memory card. And touch something metal to remove any static charge.
2) Remove all screws from exterior casing(using properly sized philips screwdriver). Devise some manner of keeping track of them.
3) Using a narrow plastic tool or similar; work your way around the seam between the two halves; gently prying until you can easily remove the rear facing.
- You should now have full access to the screen.
4) Follow the ribbon(coming from the screen) to it's connector(white and brown)
Gently open the ribbon connector. The brown piece should slide towards the ribbon and hinge open.
5) The screen itself, is just clipped and lightly glued in. So just gently pry around the screen with the plastic tool until the adhesive is broken and the screen pops out.
6) Take new screen, removing any packing materials, and insert the ribbon into the connector. Carefully sliding it in all the way. Close the brown retainer and slide to lock in.
7) Position screen inside clips - Double-stick tape can substitute the adhesive.
8) Continue reassembly in reverse of dis-assembly.
Note: If I recall correctly, reassembly is easier if you put the top of the back piece in place first.
Pitfalls:
Don't lose the screws and be careful not to strip them.
Pieces such as screen and ribbon are delicate - don't use brute force!
Case, if too much force is applied, can bend and/or distort.
Be gentle, go slow, and you should do just fine!
Alex
p.s. If you run into trouble along the way; just ask!
Mar 02, 2011 | Olympus FE-330 Digital Camera
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
How do I replace the LCD screen on a Sony cybershot dsc S930 camera.
I am not sure about the specific brand. Open the case by removing screws (usually 5-6). The LCD screen is immediately accessible. Lift it carefully and trace the ribbon connector. Lift the small flap in the connector carefully and pull out the ribbon cable. Replace it in the reverse order.
Jan 03, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Nikon L11, how to replace the LCD screen?
is very easy. you will need only a cross screw driver. This operation should take no more then 15 - 20 minutes
May 31, 2010 | Nikon Coolpix L11 Digital Camera
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Replacing the lcd screen on casio exilim ex-z77
the LCD will have a ribbon cable going around to the front and it will also have two small wires red and black for the back light. those have to be desoldiered and the ribbon cable unplugged and gently removed. I repair these camera all the time and this unit is a pain. If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Sep 30, 2008 | Casio Exilim EXZ75 Digital Camera
Replacing the screen on the 7330gz
CHPMarine -
Replacing an LCD screen in a laptop is no simple process; It generally involves dismantling a LOT of the computer just to access the connectors and brackets for the screen. I recommend having it done by a tech if you can - take a look at www.craigslist.org to find a tech in your area in need of work; many people will advertise tech support under the Services Offered position for a very low cost.
Otherwise, there are several screws you need to remove. On the bottom of the computer are generally between two and six screws that hold the power/hinge bezel in place, as well as the keyboard. Remove these screws and CAREFULLY pull up the bezel. The keyboard may also have screws under that bezel, remove those before lifting the keyboard (usually doesn't have to be completely disconnected, just shifted aside, but don't stress the ribbon cable that connects the keyboard to the motherboard too much).
With the bezel and keyboard out of the way, you should see a cable that connects the motherboard to the LCD through one of the LCD hinges. Disconnect that cable.
The plastics covering the LCD should have a handful of rubber or plastic 'plugs', between four and ten of 'em, with small screws located underneath each. Remove these screws, then very gently use a small flathead screwdriver to pry the LCD plastics apart at the seams along the side.
Once the front plastics are removed from the LCD, disconnect the long, slim PCB that rests beneath the actual screen. Remove the screws that hold the screen to the mounting brackets along its sides, and the LCD should be loose. Carefully lift it from the rear plastic cover, and you'll see a ribbon cable connected to the display. Release the clips that hold the ribbon cable in place on the screen, and you're ready to put in the new LCD!
I know its long and circuitous, but repeat the steps above in reverse to install the new screen.
Hope this helps!
-thinstatic
Jun 12, 2008 | Gateway 7330GZ Notebook
How to replace LCD monitor/screen in an Olympus C5050 camera
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
May 06, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Broken screen
On my samsung yp-k3 touch screen one side of my won't show and the other do and i can still lisern to my music.
Dec 29, 2007 | Audio Players & Recorders
Casio Exilim EX-Z750 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
