Question about HP PHOTOSMART PLUS B209A All-In-One Printer
Replaced empty black ink cartridge, wont print black ink even after cleaning and aligning the printheads
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For severe print quality or missing color issues (...printers which use HP564 ink cartridges) there could be an air bubble/gap between the ink cartridge and PRINTHEAD, or a portion of the PRINTHEAD is dry, so you should first perform a CLEAN PRINTHEAD procedure from your printers control panel (i.e. select TOOLS - CLEAN PRINTHEAD).
It it then suggested you print the SELF TEST or PRINT QUALITY REPORT (under TOOLS menu) to aid in identifying which color is causing the issue. Check that cartridge or cartridges to ensure they have plenty of ink inside.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this more severe condition, you may have to run the CLEAN PRINTHEAD procedure 2 or 3 times. Print the SELF TEST REPORT or PRINT QUALITY REPORT to see if there is any visible improvement in colors and/or print quality.
If a problem persists then it is suggested to review the steps outlined on the following Inkjet411 HP564 support page, including printhead removal/printer electrical contact cleaning and service station cleaning. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.com/?page_id=1451
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and thoroughly flush all ink ports for 2-3 minutes...thoroughly dry printhead prior to re-installing. Retest. For complete instructions refer to video here: http://inkjet411.com/?page_id=2412
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (while rated for 10-12,000 pages, the average consumer may only see an average of 5,000 printed page throughput) and may require replacement. A severe failure of the PRINTHEAD is typically accompanied by error messages such as INCOMPATIBLE PRINTHEAD, REPLACE PRINTHEAD or INK SYSTEM FAILURE. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead electrical performance, activate the Tap 41 diagnostic test, (i.e. Pen Status: Pen OK).....for printer model instructions please visit: http://inkjet411.com/?page_id=1813
To solve other HP564 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Jul 26, 2013
    Scholar:
  • 94 Answers
The head of your printer cartrige (black) are not detected by the printer because it was damage and need to be replace. So that no more black ink could print anyway.
Posted on May 26, 2010
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Feint printing
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Jul 01, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP-5 AiO says "0%" ink even after I install new cartridges
Let's clean and align.
Make sure that there are 5 - 10 sheets of plain paper loaded in the paper tray.
2 Press menu to display the main menu.
3 Press down arrow until Maintenance is selected.
4 As needed, press down arrow until the desired option is selected.
5 Press OK.
6 Follow the prompts in the display screen to initiate or cancel the task.
These available maintenance options are shown below:
Check Ink Levels
Nozzle Check
Printhead Alignment
Clean Printhead
Print Demo Sheet
Print Test Page
From windows, : Open the Home Center Help panel by clicking Help on the Home Center window, as needed. Click Maintenance, and then click
Nozzle Check or Printhead Alignment.
Macintosh: Open the Home Center window and click Maintenance, and then click Nozzle Correction or Printhead Alignment.
Should be good now.
Regards
Richard.
Apr 24, 2009 | Kodak ESP 5 Printer
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Lost B&W printing
Hi marc, it sounds like the normal clean has not eliminated the clog you may have in back printhead. I need to know if you refil your own cartridges or not to be specific, but basically you need to remove the black ink cartridge, and clean the printers heads yourself, and right down where cartridge sits wth cotton buds and proper cleaning solution. Wipe the surface of cartridge if it has the printhead attatched (some printers have the printhead on them, some have it on the cartridge. Replace ink, reset black ink level, cancel the alignment for now, go straight to printing. Print a test page and see how it goes.
Jan 26, 2007 | Canon BubbleJet i560 InkJet Printer
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
827 people viewed this question
Seeker5211
Seeker5211
