Question about Kenyon 14 in. Kiss B23006 Gas Cooktop
What is the purpose of the tube coming out of the back of the cooktop ?
  • 410 Answers
Drains the grease.
Posted on May 26, 2010
  • Robert Dufresne Jun 27, 2011
    I don't think it's right cause there is a check valve at the end of it, that requires a small pressure to open
How to remove oven thermostat on whirlpool stove
You don\'t need to remove the top. The thermostat is the long skinny tube in the oven that comes up to the railcock behind the oven control knob, remove the front panel to get the railcock/thermostat out which has the tube attached to it.
Mar 20, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
One burner has no spark for ignition..
Yes this is arcing, and should be replaced. If it is still atatched, you may be able to move it away from an area that it is arcing onto, and give it a try. Wery often it is just items in close proximity that causes the issue.
Jun 29, 2008 | GE Profile JGP636 Gas Cooktop
Regarding: GE Monogram Cooktop ZGU48N4G The problem I have is that I need to remove the brass tubes that attaches from the burner base to the inside. The brass tube (Chamfer) bound up and broke someth
I have a ZGU375ZSD. Same issue. I could not get below. I drilled a whole in the side, and used a hack saw and tin snips to cut a much larger hole so I could get vice grips on the lower nut. I bent the metal back and put some metallic tape over the whole. I figure the unit is under the counter, and in my case on the back side. GE said it was not repairable, offered me a 75% discount on a replacement. I fixed for around $400 instead of $1,200 replacement. There really is not good solution.
Dec 13, 2012 | Thermador PC366BS Stainless Steel Gas...
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Frigidaire smooth cooktop PLEC30S9EC
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Nov 02, 2006 | Frigidaire PLEC30S9EC Stainless Steel...
Open Questions:
Kenyon 14 in. Kiss B23006 Gas Cooktop Logo
114 people viewed this question
Top Kenyon Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kenyon Cooktop Expert? Answer questions, earn points and help others
