Question about McCulloch Electric Pressure Washer 1800psi 145 GPM Induction Motor Cart
Water does not come out of nozzle - McCulloch Electric Pressure Washer 1800psi 145 GPM Induction Motor Cart
No water pressure when wand is squeezed
check the nozzle isnt blocked easiest way to do this is remove pipe from lance handle and see if it fires water at pressure when lance isnt attached if it does fire water at pressure then your spray nozzle is blocked or turned off at the nozzle the nozzle can sometimes spin to far round and close
Apr 21, 2015 | Garden
The water is not coming out from water hose
Check that the nozzle jet is not clogged. To do this removed (unscrew) the nozzle at the end of your wand. Squeeze the handle. If water sprays out then your jet nozzle is clogged/corroded and either needs to be cleaned or replaced. This happens sometimes if you leave the wand sitting for several months with water still in the line.
Aug 09, 2014 | Daimer XTREME POWER XTREME POWER XPH-5900I...
No water coming out of rear windscreen washer - have changed two pumps at the front of car
A likely source of the problem is a plugged line or nozzle. Nozzle is easiest problem to fix. Disconnect hose is you have access and see if water pumps. If it does then replace or clean nozzle. Cleaning nozzles may or may not be easy.
Jan 15, 2013 | 1998 Honda Odyssey
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
My printer is going through the process, however paper comes out blank. Ink is showing to be full, but I have not used printer in over a year. Could it be the Ink cartridge?
Yes. When you don't use it for a while, the ink clogs at the nozzles.
Get it cleaned from a capable professional in the area.
If there is no one to support, you can try the following (at your own risk).
Hold the nozzles to steam from a kettle for 10-20 seconds, gently wipe the nozzles with a clean cloth or absorbent paper, and try printing.
or
Put some water into a bowl that is warm such that you can barely put your hand in. Dip the nozzles in water (Don't get the circuit part wet) and gently move the cartridge in water (again, only the nozzles should be in water). gently wipe the nozzles with a clean cloth or absorbent paper and try printing.
Sep 16, 2011 | Lexmark Z1300 InkJet Photo Printer
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
I have 2 bissell pro x2's that are now both not spraying water
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! d
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 7 will not spray water or cleaner
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Jun 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
McCulloch Electric Pressure Washer 1800psi 145 GPM Induction Motor  Cart Logo
180 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
