I keep getting a message on my computer that "virtual is low, click balloon to repair" I click the baloon and it is ok, What does this mean?
  • 4,281 Answers
For that first remove all temp files from computer.
Press windows key +R key so you can see run you can also see run in start menu.Click on run and type in run "%tmp% without ""then press enter then remove all temp files.Type in "prefetch" without "" then press ok then remove all prefetch files.
Then right click on my computer icon click on property then click on advanced tab then click on settings of performance then click on advanced tab then click on "change" button of virtual memory then click on custom size and set initial size to maximum size then apply and ok.
Also type in run "chkdsk /r" without "" then press "y" in back screen.
Then restart computer then it fix error on harddrive and recover errors.
Then it will work fine.
Also increase RAM memory if your ram memory is less than 1 GB.
You can check your ram memory size in my computer property.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 06, 2010
Low virtual memorey
just right click on my computer and properties and in that go to advanced in that you can see the thing about paging file u increase it so thati think ur problem may be solved
Oct 10, 2012 | Acer Aspire One PC Notebook
Virtual memory low, not sure how much I have got and what I can upgrade to? My desktop ser no is 11419107876?
I assume that you got a little balloon in the
bottom right-hand corner announcing that your
virtual memory is low and that Windows is
adjusting it. If this happens just once, don't
worry.
As the message said, Windows found a problem
and fixed it. But if it happens repeatedly,
it could be that your settings don't allow
Windows to make the necessary adjustment.
First, make sure your drive isn't overly full.
In Windows Explorer, right-click the drive
icon and choose Properties.
If the amount of free space is under about
10 percent, you'll need to free up some space.
You can use the Disk Cleanup button right next
to the free space indicator, or manually move
some files to off-line storage,
or uninstall unnecessary applications whatever
it takes to get more free space.
If low drive space isn't the problem, the
virtual-memory settings may be wrong.
Right-click My Computer and choose
Properties. Click the Advanced tab.
Click the Settings button in the
Performance panel.
Click the Advanced tab in the Performance dialog.
Click the Change button in the Virtual
memory panel. Whew! This setting is buried
quite thoroughly!
Look for the System managed size option,
select it if it isn't already selected,
and then click OK, OK, OK. That should end the
warnings.
Aug 17, 2010 | Targa Computers & Internet
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
I computer is slow and a message that my virtual memory is low
1. Click Start, right-click My Computer, and then click Properties.
2. In the System Properties dialog box, click the Advanced tab.
3. In the Performance pane, click Settings.
4. In the Performance Options dialog box, click the Advanced tab.
5. In the Virtual memory pane, click Change.
6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
Click OK and close .
Oct 11, 2009 | E-Machines eMachines Desktop PC
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
Virtual Memeory
farc
Main memory (in general we call RAM) r use for those protions of code and data that are actively being used. and the rest of program is stored in virtual memory of the disk. for this reson we can deal with grater amount of data or coad then ram. this is reserve space in disk in windows xp "pagefile.sys" control virtual memory.
To solve ur problem right click of "My computer" then click on "properties" then click on "advance" tab, click "setting" under Performance, then click on "advance",and then click on "change" click on "system managed size" radio button" and click on "set"( if it already selected "custom size" set initial size 500MB Maximum size 2000MB and click on set tab) then ok and again ok at last ok. and restart ur machine.
(if "system managed size" not solved ur problem then should select custom size and give the above size or as per your choice)
thank for asking
Buddhadev
Jul 02, 2008 | Asrock P4I45GV R5 Motherboard
I have windows xp service pack 2 I keep getting the error message the my virtual memory is low. How do I fix it.
Go into control panel, system, advanced. Under system performance, click settings. Click on advanced and under virtual memory click on change. Make the initial size 1024 and the max size 2048. Click okay on everything to get out of there. Reboot your computer and you're done.
Jun 29, 2008 | Northgate Computers & Internet
My vitual memory
it means the amount of hard drive free space is either low or it means you must increase the limit of this space. first remove any un-necessary files by doing the following: 1.) open explorer and click c drive. 2.) right click and select properties 3.) select "disk cleanup" now select the Tools tab above and select "check now" now select "Defragment now" next, right click "my computer" on desktop then select Advanced tab and select "settings" then select next Advanced tab and select "change" in the virtual memory area. type in the maximum under custom size and select "set" and ok out.
Sep 15, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
David Payne
David Payne
