Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS-65513 I changed the setting on the energy mode from standard to low yesterday. After the TV was shut off once, it would not turn back on and the green blinking light continues for minutes before finally stopping. I have unplugged the unit and plugged back in. I have tried the reset button. This has not fixed the problem. Please send help to email [email protected] Thanks!!
  • 51 Answers
If you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Posted on Jul 01, 2008
SOURCE:
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
TV taking a long time to initially turn on after it has been setting. The timer light will flash green for about a minute than the set will turn on.
Change the TV Energy Mode to "Fast Power On" in the Set Up menu if the TV takes an excessively long time to power on. The TV Energy Mode could be set to Low Power.
You can download the user manual from Sears.com
http://download.sears.com/own/5754146e.pdf
Oct 31, 2011 | Mitsubishi WD-65731 65" HDTV
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
TV Turns Off, Color is Turning Technicolor Blue-Green
sounds like the tube is going on the set best thing to do is consider buying a new tv or take to your local tv repair shop and they should be able to sort it for ya :D
Mar 10, 2009 | Daewoo DTQ-27U4SC 27" TV
Message that game will not play at current video setting
Hello.
You just need to restore the defaults for the video. Here is how to do this.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps!! Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Poor picture
Dynamic mode will give you a brighter picture. The energy saving mode runs the lamp at a more efficient level that saves energy at the cost of a slightly darker picture. Based upon your description, I'd guess that the lamp is nearing the end of its useful life. Plan on changing the lamp soon. When you do so, place the set back to standard mode and energy saving.
Dan
May 30, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Green Screen
Your picture tube is bad,pull back off/ unplug crt broad on neck of tube make sure it does not touch anything ,turn set back on if set stays on tube is shorted!
Dec 18, 2007 | GE 13R100T 13" TV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
