Question about General Electric Dryers
Heating element location for General Electric model# dde5300velad
aborcass
  • 2651 Answers
SOURCE: maytag electric dryer model DE410
check all of those "relays", htey are thermostats, monitoring you temps, they should all have continuity through them if not its bad. (temp jump it out) just to see the element glow. TEMPORARIly.. you CANNOT leave any jumped out you will damaged something. HOUSE FIRE. just wanted to instill the importance of not leaving jumped out
Posted on Mar 23, 2008
  • 333 Answers
SOURCE: location of heating element
The heater element on this washer ris behind the drum. You can change it from the rear or throught the top rear of the dryer. I hope this helps.
Posted on Jan 15, 2009
Raphael11
  • 54 Answers
SOURCE: general electric model spectra XL44 stove not
you need to change the bottom heating element . you can unscrew it and take it to home depo or appliance store and get a replacement and screw it back on should work fine then.......
Posted on Jul 14, 2009
garing
  • 998 Answers
SOURCE: how to change fuse in microwave
after cover is off should see fuse
Posted on Aug 09, 2009
  • 417 Answers
SOURCE: Need to replace heating element
Have you tried www.appliancepartspros.com
Posted on Jan 15, 2010
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
on Mar 20, 2010 | Dryers
Keeps kicking off the electric to the water heater at the electric box
one or both heating elements are shorting out and drawing too much current and dropping the breaker out,when you replace the offending element,replace its thermostat also located above it on most units
Jan 02, 2011 | General Electric Water Heaters
My Kenmore Elite HE4 Electric Dryer still runs but is not heating. The Manual says it could be 2 fuses or a circuit breaker but doesn't tell you where they are located. Where are the 2 fuses located?
it may be a reset switch on the motor, heating element or thermal fuse, here is a website that should help, Tim
http://www.applianceaid.com/general.html#fuse
Oct 24, 2010 | Kenmore Elite HE4 Electric Dryer
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
8'' electric stove top element not working
timer on what ? make, model and age of unit might be useful in forming a coherent response.
Mar 07, 2017 | General Electric Stove/Oven/Range Chrome...
Dryers Logo
35 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
