Question about Polaroid 1720-7 Remote Control
Can not turn TV on or off with remote every other function works
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Make sure u press tv then try it
Posted on May 30, 2010
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
Mitsubishi tv remote will not turn tv on. put in new batteries already . only the red light on the tv button turns on.
You should reprogram your remote. Start with the tv on. You have got to find a code that will operate all of the functions you want it to. In others some code will only turn on the tv. Some codes will work with volume and the channels. Once you find a code that works you should be able to operate the tv with the remote. It sounds like to me when you put new batteries you erased the function of your mitsbishi remote. So once the tv turns off you have found your code.. but make sure before you save it you write down on something; and, it works all of the functions that you want it to. I hope that this helps a ton...
Jun 29, 2014 | Mitsubishi New Original 290P137C10 Remote...
Functions on Sharper Image remote control won't work
Try it with an other code to your device.
Feb 17, 2013 | Televison & Video
I got my dish network to turn off the tv and adjust volume but remote wont turn on the tv
Hi there!! This is Kimberly Escobar with DISH Network, just ran across your post and wanted to provide you with some helpful information to help get your problem resolved. If your remote control is functioning as far as turning the T.V off and the volume, one of the things you may want to check is that the power button is working, you can verify this by trying to turn on and off the receiver. If it works for the receiver you will need to try to address the remote to your T.V again using different codes. To address a remote to the T.V we use certain codes that integrate to the remote allowing it to function with the T.V. unfortunately we cannot promise the remote will function the T.V completely. You can find more codes at this link here http://www.dishnetwork.com/SupportSection/remote-setup. If you need any additional help please free to contact us directly at 1800-333-DISH. Hope this is helpful to you.
Feb 10, 2011 | DISH Network IR Remote Control
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Nov 07, 2009 | Sharp 32C-240 32" TV
Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
Feb 08, 2009 | RCA RCR412B Remote Control
Universal remote locked out TV
I was able to get back to using the TV after several frustrating tries at finding the right combination of searches and pressing buttons. The function I was able access was not a function I could get to with the remote suppilied with the TV. And once stuck in this mode nothing would clear it Turns out that the power button gave me channel 8 and the #1 button gave me this display calibration? function. Obviously not using the right code. Never the less all is well with the TV and I got my VCR working with the $2.99 remote and I will attempt the other units TV and Magnasonic DVD later when I have regained my composure.
Nov 29, 2008 | Universal Televison & Video
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Televison & Video Logo
232 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
