Delete and reinstall the printer driver ... get the newest driver at www.dell.com/support
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/AbnM39. Select your operating system, download and execute the file. After the install process, try to print again.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
