Question about KitchenAid KAWS700L Top Load Washer
It doesnt spin
The machine was making a noise like something was in the pump. aftyer checking the pump i realized it wasnt the pump at all the machine doent spin and makes a noise like plastic gears are not lined up thank you Wayne
  • KitchenAid Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machineit doesnt spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 26, 2010
Maytag MAV7550AWW makes very loud noise while draining, although it still drains and spins out.
Check the pump. Maybe a coin or something got in the impellers. Another is to check the belt and pulley along with the mounting of the pump.
Jan 15, 2014 | Washing Machines
I have a maytag fav6800aww and it doesnt want to drain the water and it makes a loud noise coming from the pump. i already replaced the pump and it still has the same symptoms. what should i do to fix this...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Well when it spins it makes a noise but not the whole time the it stops and starts again only during spin cycle.
If you put it onto just the drain cycle does it still make the noise without the drum spinning,if so then you can expect to find something stuck in the pump.If it is only doing it on the spin cycle then something has found its way into the drum.
Check the pump end first.
Hope this helps.
Aug 20, 2010 | Washing Machines
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My washer has benn making a sound once in a while like a wine today though it sounded like something was stuck in the drum or like rocks in it now it just hums during the spin it fills up washes but doesnt...
If you might have got the sharp sound every here and then, tub might be imbalanced.However, if that's intermittent and sound is only during spin, more likely something caught in the drain pump making that noise.
A generic solution how to clean drain pipe :-
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 12, 2009 | Washing Machines
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Maytag MAV7600 - loud noise on spin cycle
It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Dec 26, 2007 | Maytag MAV7600 Top Load Washer
Whirlpool Top load LSQ9110LWD
Does it sound like a bearing noise or more a grinding noise. Could something maybe be stuck in the drain pump. When does it actually make the noise?
Oct 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid KAWS700L Top Load Washer Logo
168 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
