Question about Grohe Grohtherm Thermostatic Rough-In Valve 3/4'' Valve - 34125000
I need to remove 2 Grohe 19 724 Pressure Balance Valve trims (one shower, one bath). I can't figure out how the escutcheons come off? Are they connected to the plastic part and snapped in? I notice 2 brass screws that connect the plastic to the rough in valve- but can't get to the front of them to unscrew. Help please:)
Try rotating the faceplate in counter-clock wise fashion. this is a maybe.
Posted on Jul 23, 2010
Nee installation manual for a special care shower to take apart a Greohe Grohmix thermostatic/pressure balance mixing valve, model #34.421. this is a discontinued model. I've been able to get
Grohe or AKA Hans Grohe will send you a manual if necessary or if you spell it right you can find a copy online to download. I imagine you missed removing a retainer.
Sep 09, 2014 | Water Heaters
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Dec 17, 2012 | Water Heaters
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
I have a grohe 19 614 thermostatic valve / mixer. I want to adjust it so that the wateris hotter than what is coming out right now. I have the diagram showing how to take the trim off, and shows where to...
http://docs.homeclick.com/PE-Links/Grohe/Grohe-19614-manual.pdf
1. Turn thermostat handle (L) to the 100 °F (38 °C) safety
check, see fig. [6].
2. Unscrew handle (N) or lever (O).
3. Unscrew cap (M).
4. Pull off thermostat handle (L).
5. Remove screws (H) and escutcheon (G), see fig. [4].
6. Close both isolation valves (I).
7. Pull sleeve (F) from the mixer shank by pressing
down the tongue (D2), see fig. [7].
8. Extract clamp (D1).
9. Pull stop ring (D) until resistance is encountered
(approximately 3/8" [10mm]), see fig. [8].
10. Unscrew stop ring (D) complete with regulator
nut (K).
11. Unscrew thermoelement (47 050, 47 582) with 24mm
open-ended wrench, see page 2.
It is not too clear to me, but I'm not looking at it. lol
Gary
Dec 14, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Grohe Grohtherm Thermostatic Rough-In Valve 3/4'' Valve - 34125000 Logo
    318 people viewed this question
    Top Grohe Water Heaters Experts
    Paul Carew
    ray gallant
    Shimon David
    Shimon David
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
