Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony T.V. KV-36HS500
We purchased this t.v. in 2002, this weekend it won't turn on and the red blinking light is flashing 6 times.I shut it off from 24-48 hours and still it won't turn on. I called the number in the manual that came with the t.v. and they were no help at all. Couldn't tell us what the problem would be and just suggested to call a repairman. Well this t.v. is way to heavy to bring anywhere.
Would you have any idea what the problem would be and what would the approximate cost be?
  • ralctl Sep 29, 2008
    Can you name the correct number for these caps.
  • muffygill Oct 22, 2008
    We are experiencing this same problem (bad timing with the World Series here in FLoirda) Especially since my husband has been a Devil Rays fan since their inception. My ex ran a TV shop for 12 years and suggested it was the FlyBack. I will be calling the repairman tomorrow and hoping for the best. THANKS for the POSTS!!!
I have this tv, and had the same problem. I just had a repairman come (because almost all of them make house calls for a 20-30 fee to be included in the repair charge if you use them) and for $275 he fixed everything.. all set. Good luck!
Posted on Apr 07, 2008
  • 4,234 Answers
This problem has been reported by others in another forum and was traced to the "D" board. There are a number of capacitors that need to be replaced. The "D" board is no longer available as a replacemetn part, so it needs to be repaired. These caps are not expensive, so the repair should not be too bad. Figure on $20 or so for parts pluse the local laboir charge.
Dan
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY KV-36HS500 will not turn on. Stand-by mode blinks 6 times then repeats. Repair man checked out our phone system earlier today for signal loss and put 500 V generator on phone line to house to check...
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Aug 12, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No picture or sound
6 blinks usually means a loss of the horizontal signal. This can be as simple as a bad capacitor or jungle IC. I'll look up your specific model, but do you intend to repair this yourself? If so, please update this and I'll provide additional details and instructions.
Dan
Mar 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My KV-36HS500 won't turn on it sounds like it wants to,but no picture,and standby light flashes 7 times,pauses and flashes 7 times again
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wegakv36hs500 fd trinitron
The flashing light normaly indicates that the power supply section is in the protect mode, or has failed, and or there is a failure in the scan amplifier section, and or there is a short most likely there may be a short. There are many things that can cause this type of fault. You will have to take the set to a Sony service center or the equivement to have your set properly serviced.
Jerry G.
Oct 25, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
