Question about Elna 1010
Looping thread on backside.
I am having problems with loops on the back side of the fabric. This has occured with a variety of fabrics. Right now I am working with a basic 100% cotton, standard thread. I am using the B stich and a 2 length. I have tried adjusting the tension and changed needles. I also have noticed the bobbin gets tangled quite a bit.
Any thoughts?
Thank you
  • Anonymous Oct 22, 2008
    i also have an issue with my elna 1010 loopoing on the backside. i would like to clean the feeddog but i cant get the needle plate off.
I have a 26 year old Elna and this is the only weakness it has. Before sewing, try this. Turn the wheel manually and watch the upper thread pick up the bobbin thread. Pull both back to the left. Make sure they are plenty long. This helps me prevent the tangling in the dogfeed. My Elna has a universal tension on the bottom and I haven't ever had a problem with it unless the top tension is too tight.
Posted on Sep 21, 2008
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
How do i adjust my consew 105 so the stitches do not loop on the bottom?
If the thread is looping under the fabric, it is a top tension issue.
Make sure you are using a new needle and that the needle/thread/fabric are compatible.
Verify it is threaded correctly and that the thread is firmly seated in the tension disks.
If the top thread is still looping under the fabric, then the upper tension is too loose.
Nov 07, 2016 | Consew Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
Bottom thread is looping on top of fabric on my Singer Futura 400 machine
Thread looping can also be caused by the use of adhesive stabilizers. During embroidery, your needle can gum up. Try floating a sheet of wax paper on the bottom to see if that might be the cause (along with the above solutions, of course).
Mar 04, 2014 | Singer CE250 Computerized Sewing Machine
Upper thread looping around bobbin
make sure your needle is positioned correctly? not too high and not too low.
Jan 10, 2014 | Brother Sewing Machines
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
Looping thread bottom side of fabric
That means you have not routed the bobbin thread properly, or bobbin has not been filled properly. Could also mean your tension is incorrect.
Feb 14, 2010 | Brother Sewing Machines
My bobbin thread is making big loops
Bottom looping says upper tension problems (too loose). Rethread it making sure the presser foot is up so the thread is inbetween the tension discs.
Dec 11, 2008 | Bernina Bernette 75
Sewing Machines Logo
298 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
