Question about Canon PIXMA MP620 All-In-One InkJet Printer
No ink the questions is: how i can print some picture w/out one ink,,absolute is the yellow ink,but i have de rest ink,,what i have to do in the printer? thank
    Sergeant:
  • 284 Answers
You cant do any more printing jobs unless replace the yellow cartridge.
Posted on May 26, 2010
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
My pictures are getting yellow streaks as they print out
If you are getting "yellow streaks", run the Kodak "print-head-cleaning" software, to see if that helps.
Be sure to compare the cost of "repairing" the printer to that of buying a new printer (that would use the same ink-cartridges).
Jul 03, 2010 | Kodak EasyShare Thermal Photo Printer
Brothers MFC885cw can't recognize new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Brother Multi-Function Center MFC-240C...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
No good pictures
The symbols you are seeing are the blur warning indicators.
The yellow hand warns you that the picture may not be quite sharp enough for a standard 6" x 4" print - however you may be happy with it.
The red hand warns you that the picture is most likely to be poor quality, and won't produce a good 6" x 4" printed photo.
The reason you're getting these indoors, is that there's not enough light for the camera to take a good picture. As it tries to do so, it opens the shutter for longer to let more light in - however on doing so, if the camera isn't absolutely still, then the warning symbols will come on.
To remedy the above I'd have the following suggestion - if possible and practical, when shooting indoors, try and rest the camera on something solid when taking a photo. If this is not possible - try leaning against a wall to stabilise yourself. Even though you think you are holding the camera still - it's moving quite a lot.
Try one hand held photo - and one photo with the camera resting on something solid like a table and see what the difference is.
May 24, 2009 | Kodak EasyShare C743 Digital Camera
MFC-420CN does not print black
My yellow cartridge was doing the same thing as your black. So I took the cartridge out, and took a flashlight to see how it works. There is like a little straw on the right hand side which goes up into the printer cartridge, this I assume is to measure the ink. I took a needle and cleaned that 'straw' thoroughly. Reseated the ink, ran cleaning and test print, and then the printer found the yellow ink! You could give that a try. It might work for you too. (I have never used any ink but Brother ink in the printer, btw.)
Apr 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Colour Printing
Will it print internal reports in color? Can you perform a maintenance head cleaning cycle?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
