Question about Frigidaire FAC124 wall/Window Air Conditioner
Turned on unit and it runs for 30-45 seconds and kicks back off, and never blows out any air at all. Not hot, cold, nothing. What is wrong with it? It's a Frigidaire FAC124P1A model.
  • 901 Answers
Check compressor capacitor. Then other parts like fan/ capacitor.
Posted on May 27, 2010
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
Apr 02, 2016 | Heating & Cooling
Hayward 100 series not blowing out air
if new heater and wired 120 volt check wiring try to reverse sounds like not showing rectification if old unit bad flame sensor
Jul 11, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run...
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Jul 20, 2013 | Heating & Cooling
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
Sep 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
I have a Ruud air conditioner model #13AJA36A01757. The temperture out of the vents is only 70 degrees while it is running. Outside unit, low side is very cold, and the high side is not hot, not even...
If your vents are in the floor, you need to inspect your return air ductwork, you may have some air leaks pulling hot attic air in thru the vents. If the supply vents are in the floor, the return duct may run through your attic, if the duct work is uninsulated or pulled apart, it will pull hot air thru the return, causing a mixture of cold and hot air, giving you a warm air movement through the ductwork. Many service men will not catch this problem. You need to turn the unit on, go up in the attic and visibly inspect the entire return air. I hope this helps you. mark
Aug 14, 2011 | Ruud Heating & Cooling
Describe your &safe=images Problem1999
Comprerssor could have gone out....could be a bad low pressure switch...could need a small charge to bring it up to where it needs to be to operate
Sep 14, 2009 | 1999 Mercury Grand Marquis
Runs doesn't cool
where is the air filter for the ruud ( #uak037jaz) air conditioner
Sep 05, 2007 | Heating & Cooling
Frigidaire FAC124 wall/Window Air Conditioner Logo
157 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
