Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My steering wheel will not turn towards the right. it sounds like it stripping gears. How do i repair it?
    Problem Solver:
  • 7 Answers
Raise the hood and follow the steering wheel shaft down ti the gears. u either have gears stripped or a worn out bushing.get parts and replace or have a lawnmower repair person do it.
Posted on Jun 08, 2010
My89 dodge dakotas steering is copletely loose and wheels dont turn at all everything seems to be attached,whats the problem
where to start? any steering fluid? steering belt ok? steering wheel tight? steering pump ok? front end pitman and idler arm(s) ok? front end bushings or rod ends ok? steering box gears steipped? steering rack could be stripped. check all these first then get back to me.
Jun 05, 2016 | Dodge Cars & Trucks
What makes your tires not move when u turn your steering wheel on a 1999 chrysler 300 m
gear stripped at steering wheel to shaft, stripped steering gear at the rack n pinion. Inspect steering shaft and connections.
CHeck here first:
I doubt its here, but if not anywhere else, check here:
Dec 08, 2013 | 1999 Chrysler 300M
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
Steering wheel gear is stripped
Please for the love of god tell me you have an answer to this, same problem, sooo angry, hit me up at reid72@aol.com pleeeesee
Jul 15, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
2005 honda odyssey radio controls on the steering wheel, the volume up button changes the station while the volume down button turns up the volume
there is a service bulletin about this. the steering wheel has to be removed along with the switch gear. then the steering shaft ring that makes contact for these controls while the wheel is being turned need to be gently dimpled to make better contact. if the dimples are too extremem the whole steering column will need replaced.
Jan 23, 2010 | 2005 Honda Odyssey
The steering on my Husquavana 150 mower is slack and uneven, it turns sharp to left but not to right. Gear wheel at end of steering shaft is worn. How do I repair it with more sustainable solution. Thank...
replace steering gear and lower nyliner bushings on steering shaft. Also check sector gear for wear and replace if needed. When replacing gear place front wheels straight forward and center steering wheel-the unit should steer the same both ways then.
Nov 22, 2009 | Husqvarna Garden
Steering problem
binding linkage, or most likely steering gear
Aug 30, 2009 | 2004 Chevrolet Silverado
Car make screeming noising when turning steering wheel
turn the wheel all the way to the right till you hit the end of it's travel... move it back and forth toward the end... shut off the motor and check the power steering level fill if needed... now do it toward the left side. check the fluid level when you are done... is the noise still there ?
Jan 31, 2009 | 1999 Subaru Forester
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
381 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
