Question about Brother 2440C Colour Plain Paper Inkjet Fax
Resetting fax name and number
We run a family business from home and have recently changed our business name and number. i still have the previous details registered on the fax machine and I'm having trouble changing it to our new details. can you help?
thanks, kristen
    New Friend:
  • 116 Answers
GO MENU, INITIAL SETUP ,THERE U CAN FIND
Posted on Jun 14, 2010
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
I have been unable to send faxes to different numbers for months now. I keep getting Error 344. It always sounds like HP 3050 is able to go as far as establishing the connection and then it fails. Please...
Faxing
  1. Turn Off JBig compression.
  2. Move the fax to another location. It may be that they have noise on the line, an alarm, etc.
  3. Turn ECM Off , turn Off V.34 and set the baud rate to 9,600 or lower.
  4. Ensure fax firmware version is at the latest.
  5. Ensure firmware version for fax matches device firmware.
  6. Ensure that the device is using an analog line and phone cable that came with unit.
  7. Reset fax to factory defaults; configure just the basic settings needed to operate (country code, company name, and fax number).
  8. Reseat fax modem in formatter (or Xircom card if legacy MFP).
  9. Try a disk init. (Contact your regions HP Customer Care Center for these steps)
Aug 03, 2010 | HP LaserJet 3050 All-In-One Printer
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
Given a Brother 590MC FAX machine, Need to remove previous detail
You can go under (menu) and then (Initial Setup) and using up or down tabs move till you see Machine ID. Press (menu) or (ok) button and change phone, fax number, and name. Press(ok) button after each is set to your specification. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
Resetting the name of company and telephone number on fax sheet
Welcome to FixYa! I'm the expert that chose your issue to resolve. Now let's get started. Office machines, for whatever reason, seem to be a lot more complicated than the ones you use at home. But, this should be an easy problem to fix. The process of putting in your required and company information is known as "registration" To complete your registration do the following:
  1. Press Function, then
  2. Data Registration, then
  3. Press set three (3) times. Your current settings will be displayed.
  4. Use the numeric keypad to enter the correct month, day, year and time in the following order: Year (enter only the last two digits), Time (use 24 hour time format i.e. 13:00 vs. 1:00, precede single digits with a zero (0) i.e 01:00) If you make a mistake press clear. Also, you can use the left/right arrows to move the cursor under just one digit and use the number keypad to change it.
  5. Press set two times. The display will show UNIT TELEPHONE, the TEL=
  6. Use the number keypad to enter your fax/telephone number (max 20 digits including spaces) If you want to enter spaces, press function, then space. If you make a mistake, press clear and reenter the number. You can also use the right arrow key to delete the rightmost digit and re-enter the number.
  7. Press Set twice. Unit will display UNIT NAME on 1st Press, then on the 2nd press a blank screen (not totally blank, it will have a cursor on the left and a A: on the right.
  8. Use the numeric pad (corresponding to letters printed on keys) to enter the company name (max 24 characters including spaces).
  9. Press Set (Unit will display TX TERMINAL ID)
  10. Press Stop/Reset to return to the standby mode.
Note: if you want to check that what you put in is what you want, you can print user data list. Here's how:
  1. Press function, then:
  2. Press report (unit will display ACTIVITY REPORT)
  3. Use up/down arrows to select USER DATA LIST.
  4. Press Set once, the list will be printed.
(information above from Canon)
That's about it....I imagine that in a busy office, it's hard to find time to read through a book just to do this stuff, but I have the time.
Thanks for using FixYa.com!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Jan 20, 2009 | Canon FAXPHONE L80 Laser
Want to change the Header
Press Data registation,on usersettings press set,press the arrows untill you get unit name,press set,insert you company name there.
To change the fax number-under usersettings select unit number and change it to your number.
Jan 12, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
Change phone number
Hi, Below are the instruction for that. You can find the full operators manual at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=fax2820_us_as&type2=8&flang=English&dlid=
Hope that helps...
Lbcoaster
You should store your name and fax number to be
printed on all fax pages that you send.
1 Press Menu/Set.
2 Press 0.
3 Press 3.
4 Enter your fax number (up to 20 digits) on
the dial pad, and then press Menu/Set.
5 Enter your telephone number (up to 20
digits) on the dial pad, and then press
Menu/Set.
(If your telephone number and fax number
are the same, enter the same number
again.)
6 Use the dial pad to enter your name (up to
20 characters), and then press Menu/Set.
7 Press Stop/Exit.
6 Set the Date and Time
Year:2007
Month:03
Day:01
Time:15:25
If you make a mistake, press Stop/Exit to
start from Step
1.
7 Set your Station ID
Fax:_
Tel:_
Refer to the following chart for entering
your name.
If you need to enter a character that is on
the same key as the previous character,
press to move the cursor to the right.
Press
key
One
time
Two
times
Three
times
Four
times
2 A B C 2
3 D E F 3
4 G H I 4
5 J K L 5
6 M N O 6
7 P Q R S
8 T U V 8
9 W X Y Z
For more details, see “Entering Text” in
Aug 01, 2008 | Brother IntelliFax-2820 Laser Fax
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Brother 2440C Colour Plain Paper Inkjet Fax Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
