Question about GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Fridge and freezer no longer cold
The unit purchased used and it worked fine for 1 week. I adjusted temprature warmer to #7 was set at #9, Now fridge anf freezer both 60F, Fridge was at 34F and freezer 0F. The machine is running but the compressor is no longer cycling on. I set the both fridge and freezer to #9 again, same thing not cooling. Any help would be appreciated.
  • GE Master
  • 1,606 Answers
Sounds like a bad compressor relay on the main control board . To verify , pull the refrig out and unplug . Remove the 8X10 small cover , to expose the control board . Look for the blue plug with 3 larger wires going to it and disconnect from the board . Looking at the plug , you will see : wire1 , wire2 , space , wire 3 . Use a jumper from wire1 to wire3 and plug the refrig back in . This will send power directly to the compressor , indicating the board is bad if the compressor starts . If it starts , remove the control board and look on the solder side just opposite the " black boxes " and look for a bulls eye ( pin in the middle where the solder has melted away from it . Resolder this pin . If no bulls eye , replace the main board as the relay is shorted internally . If replaceing the board , your model NUMBER is important to get the correct board . Only 2 boards but model number necessary .
Posted on May 26, 2010
Testimonial: "100% dead on the money...shorting pin 1 to 3 fired it right up. You are the GURU!!!!"
Hy i have a problem with my fridge freezer , the fridge compartment is acting like a freezer going up to -16
There is normally an adjustment knob inside the fridge, in the back or top to allow you to adjust the coldness. Numbered 1-9.
If you have already adjusted that it would help if I know the type (side by side, freezer on top or below) and the brand. Most side by sides blow some of the air from the freezer side into the fridge side with internal fans and vents. How is the freezer side coldness knob adjusted?
I would set both knobs to 5 and go get yourself a outdoor thermometer to put in each side. It should be about 35 in the fridge and about zero in the freezer. Remember it will be warmer in the top and colder in the bottom of each.
Was the thermostat you replaced in the freezer or fridge?
Feb 02, 2015 | Refrigerators
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
I have a fridge/bottom freezer fridge and i would like to know at what temprature i should set my fridge. Its a manual setting ranging from 1 to 7. which is the coolest setting?
#1 is warmest going colder as you go upto #7.fridges should be set at +3C,adjusting the control for summer and winter.you could do the lettuce test,if it goes soggy/black,its too cold.
Jan 25, 2011 | Whirlpool Refrigerators
THE FRIDGE SECTION IS FREEZING , AFTER WE HAD THE FREEZER REPAIRED
more than likey a provisions compartment fan ,(fridge compartment) symptoms include temprature stratifcation( where product freezes in lower part of refrigerator eg: crisper draws and top shelf warmer....
fan may appear to be functioning but broken wire may cause intermittent operation ..you can test these fans remove fan ...and test with square 9 volt battery or 12volt d.c supply....i hope this could be of use
ozzie fridge tech...;)
May 21, 2010 | Fisher and Paykel Active Smart E522B...
What is the lowest setting on the temp on a Hotpoint Ctf18ga
Hello Dustin,
Typically the lower the Letter or Number is the warmer setting for the freezer or fridge section. If you want to make them colder, move the control setting ONE (1) increment at a time, in any 24 hour time period (up or down) and allow the fridge to adjust before making another change in the settings.
Again, A is warmer than B, and 1 is warmer than 2, and so on. So going to a higher letter or number, will make the unit colder.
Just remember it will take at least 24 hours for your unit to adjust and compensate for the changes, so only make them gradually, so you can tell if you've reached the desired cooling settings for both the fridge and the freezer. Typically, most manufacturers recommend that the starting position be in the middle of the dial and that you adjust them up or down from there.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
I recently purchased a home. The kitchen has a
Firstly, the thermostats are usually calibrated at one elevation and where the fridge ends up may be above or below that so the number settings on the dial aren't that relevant. You should adjust the thermostat in increments then check the temperature after 24 hours, then adjust again if necessary. The fridge should be as close to 40 degrees F. as possible and the freezer about 26 degrees F. (if memory serves me). The heat you detected is the unit in defrost cycle and should be considered normal if intermittent and a problem if constant. There should be a switch to turn off and on the defrost feature if you determine it's a problem.
I hope this helps you and good luck.
Sep 03, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
Fridge side not cold-freezer great
there is a three prong replay that hooks up to your compressor sounds like it needs to be replaced
Sep 01, 2008 | Refrigerators
TOO Warm....fresh food
IT SOUNDS LIKE THE AIR DUCT TO THE FRIG. MIGHT BE STARTING TO FREEZE UP,CHECK THIS FIRST ALSO MAKE SURE TEMP THERMOSTAT IS ON INITIAL SETTING,LET ME KNOW-MIKE
Jun 24, 2008 | Amana ATB1836AR Top Freezer Refrigerator
GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
146 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
