Question about Intex 2100 Gallons Hours Sand Filter Pump w Leaf Catcher
Pump shuts off after a minute and isn't filtering water
I have just pruchased the intex sand filter pump model sf20110.. I set it up forgeting to add the sand lol and it worked fine but oviously didn't clean the pool.. so i took it apart.. reasumbled it step by step adding the sand. now when i start it it doesn't filter and the pump shuts off after a minute.. I have to wait 5 minutes before it will trn on.. what am I doing wrong that the pump won't run/ filter the water through?
    Problem Solver:
  • 22 Answers
There is something blocking the passage of the water, go through and check all the passages for any kind of blockage
Posted on Jun 17, 2010
Sand filter pump, model SF20110. How can I rewire?
rewire ?? are you meaning to say you'd like to operate it on a different voltage than its set for now ? not all motors are changeable , if one is a (multivoltage) type motor it will have a name plate to say for example 110-240 or 208-277 does yours say anthign like this on it ??
Sep 03, 2015 | Intex Pool & Spa
I have a new Intex sand filter 3000gph I shut it off to backflush it and it will not turn on its not the electrical source any suggestions?
Intex 2650 gal/hr Sand Filter Pump Setup Instructions ...
? 10:52
www.youtube.com/watch?v=uS_95spxFaM
Feb 3, 2011 - Uploaded by Blue Fade Marketplace This video show in detail how to setup the Intex 2650 gal/hr Sand Filter ... 16" Intex 2650 gph Pool Sand Filter Pump Instructional Video 56671 ...
Jul 23, 2015 | Intex Garden
Why does intex filter pump warm water into pool?
im not aware of this unit having a heater on it if your saying that running the filter raises the temp in pool , ck to see if the pump is facing south east , if so move entire pool to a NW side , or add some sort of sun shade to pump
Jul 07, 2014 | INTEX Sand Filter Pump
Motor pump is loud
i moved mine around to under a little 4 person deck i constructed out of wood and closed it all in with latice makes it a bit fun to access but wow cuts way down on the noise now , with outdoor carpet on top of deck you can barley hear it now if your not as handy as me im sure a good skilled handyman can fab you up one
Jun 28, 2014 | INTEX Sand Filter Pump
I need a repair kit for a sandfliter modle number 20110 do you have this
Sir,
This is an easy fix. You will have to take the filter assembly apart. Go to your local pool shop ,ask for Silica filter pool sand. You will notice a gasket on the top. Be gentle with that. Mark the orientation of the pump head. Take a picture or two. Eye ball the level before you start to clean it. Magic mark outside.
Get a clean wheel barrel or a tub. Flush the sand and grit from the vessel. Be careful of the tubes on the inside. You can wash the sand clean from all the debris or replace it. I would replace it. I believe 2 bags should do it. Cheap. Have done a few. Worth the effort. You will be happy you did. The whole process takes about 3 hours including the purchase of the product. Reseal all your connections with new pipe sealant or tape.
The largest failure when doing this is air infiltration by suction. Tighten enough but not too much and mark all your plumbing with matched coding tape until done,clearly identified, if your knew at this project. There are a rainbow of colors to choose from and the alphabet, I hope your days are wet and relaxing. Do not let the word kit stop you. All that is in the filter is SILICA sand. Make sure you get that for replacement. They have figured for you. Good Day.
Here is the online Intek store link should you need more than just sand,
Search results for SF20110 sand filter pump
16 in Krystal Clear Sand Filter Pump GFCI
In conclusion, I highly suggest you watch this video. It is Intek supported. I agree with its message. Intex 2650 gal hr Sand Filter Pump Setup Instructions .
Jun 20, 2014 | Computers & Internet
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
Intex sand filter not working
timer set to bypass? try ON if all good , timer is bad look for water damage sometimes water gets inside and rusts stuff all up
Jun 17, 2013 | INTEX Sand Filter Pump
Hi- I'm a new intex above ground metal frame pool owner. I bought the saltwater chlorinator to go with my pool. I constantly have a problem with the pool filter not getting enough water to flow through...
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Intex 2100 Gallons  Hours Sand Filter Pump w Leaf Catcher Logo
437 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
