Question about Fisher and Paykel IWL12 Top Load Washer
Hi, I have Fisher & Paykel washing machine. It is an Aqua Smart , Model WL80T65CW1, Product 93220-B. I have just moved from Sydney to Jakarta and brought my washing machine with me. When I plugged it in and tried to do a load a service message came up - could you please advise what this error means and how to fix? I noticed no water was flowing into the machine (I checked external water connection and it was fine). I have located a technician who can help but being in Jakarta can't speak English but have an interpreter. Please assist. Tried calling customer service and got no where because I am not located in AU or NZ. Thank you, Alison in Jakarta
  • A Cook May 31, 2010
    Fisher and Paykel Aqua Smart Model WL80T65CWI (Product 93220-B). Fault / Service / Issue code 130 comes up when I try to start a load (ie when water pumps into machine) or during a cycle. Please advise what this '130' is so that I can fix. I don't believe it is an issue with the water flow, but cannot locate where issue is. I am in Jakarta so no access to Fisher and Paykel technician although I have located a local Indonesian technician to help me.
    Any help would be greatly appreciated
    Thanks
    A
    President:
  • 1,554 Answers
Check the wiring harness connection between the rotor position sensor and the motor controller module. Check for corrosion on the edge connector of the rotor position sensor and the motor controller module.
Check the contacts on the rotor position sensor end of the hall harness to see if any have been damaged. Each set of contacts in the socket has two wipers. Replace the rotor position sensor harness if the distance between these wipers varies between different contacts.
The rotor position sensor is located on the motor stator.
Posted on May 31, 2010
    Brigadier General:
  • 3,917 Answers
Since the service message might come due to any of the following reasons like wiring faults, water valve faults or programme control faults, I am providing you a link which would take you step by step troubleshooting to figure out the main cause.
http://www.washerhelp.co.uk/diy-repair-help.html
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 26, 2010
  • A Cook May 27, 2010
    Hi e-Guru
    Sorry for late reply ... internet network was down.
    Today I plugged my machine and it miraculously worked - water ran into the machine and it started spinning. However during the wash cycle it stopped and had same service fault 130. I forgot to mention this previously in my problem (sorry!).
    Would the solution provided in your reply apply to this issue with the wash cycle?
    I tried the rinse and spin cycle and it worked fine.
    Look forward to your reply.
    Many thanks,
    Alison
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
May 26, 2010 | Washing Machines
Fisher and Paykel Smart Drive Washing Machine Model GW609
Yes its a simple job much like a garden hose , I you live in Sydney keep your eye out for the council clean ups as they are usually interchangeable and get thrown out with the machines but washing machine stores can supply you with one .
Aug 07, 2017 | Fisher Paykel EcoSmart GWL15
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
289 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
